I've searched the numerous topics on this, but nothing seems to be working for me on this problem...Not sure if there's anything specific to this setup I'm missing...It's alot spongier than it ever used to be on a standard setup.
SPEC: Yellow band master cylinder, no FAM7821, wilwood prop. valve in rear line (bulkhead), fiesta front calipers (nipples at top), cupronickel and braided pipes throughout.
I can get the pedal to the floor, it takes alot of effort - i.e. two feet, me gritting my teeth and the master cylinder bobbing up and down in front of the scuttle (it is attached, just deflection in the mounts), but it still hits the floor which I don't like one bit... Oh and all the leaks I was posting about earlier have been fixed, the pedal does not creep either..
I have been through 5 litres of fluid trying to bleed this and have finally thrown in the towel! There is NO AIR at all coming through the nipples. Have tried two man method, eezibleed, pushing pistons back into calipers, car nose up, car nose down, dancing in a circle whilst praying to some hydraulic messiah and various combinations of all of the above but IT'S STILL NOT WORKING!!!
I did not bench bleed the master before fitting, sounds messy and I've never had trouble bleeding this in the past. This leads me to believe it's either the proportioning valve or the calipers. If I crack a front caliper and push down so I'm only on the rear circuit, the pedal is very firm. If I crack the rears then the front circuit seems very spongy so I think I have eliminated the prop valve by this method (although the 'out' is lower than the 'in' on the valve, I have not found a single snip on the web about these trapping air in them).
But is the above test doing what I think it is? Am I really isolating the f/r circuits??
Guessworks has said a couple of times about systematically bleeding the system by isolating various parts with a bleed nipple - sounds very logical but how would I do this without making a complete mess though?!
Anyone else with Fiesta calipers and a spongy pedal? I'm concerned I've fitted some orrible flexy, big bore calipers and I'm always going to have to shove a load of fluid about.
I cannot drive the car at the mo so I'm not sure what pedal effort it take to lock the fronts, but I hate spongy brake pedals and I think it's dubious whether it would get through a (strict) MOT.
Cheers for any help you can offer, it's very much appreciated!
al
