Aluminium Door Skins
Posted 01 October 2008 - 04:54 PM
i saw somewhere that the alu door skins were riveted on so no welding was needed. as i cant weld this would be a good solution.
what are your thoughts?
Posted 01 October 2008 - 05:25 PM
Posted 01 October 2008 - 05:39 PM
but i agree, fitting alu skins on a rusty frame is a bit pointless, you'll only have to take them off when the frames rot through.
get the lot repaired properly, then fit the skins is your best bet.
Posted 01 October 2008 - 05:41 PM
Posted 01 October 2008 - 06:45 PM
but thats besides the point. the question was how do you fit alu door skins and do they need welding on as i read somewhere that they can be rivited.
the minidoor company do nice streetfighter door i agree and i nearly bought some. but the total cost for what i wanted came to £530 inc shipping!!!
the alu skins are £25 each. quite a price difference.
so , can someone without welding skills fit them?
Posted 01 October 2008 - 06:52 PM
michael
Posted 01 October 2008 - 07:06 PM
Posted 01 October 2008 - 07:09 PM
Posted 01 October 2008 - 07:12 PM
Posted 01 October 2008 - 07:19 PM
Posted 01 October 2008 - 07:48 PM
Posted 01 October 2008 - 08:19 PM
but i am not sure someone with better knowledge of brazing will have to answer more
michael
Posted 01 October 2008 - 09:04 PM
I wouldnt fit them though, as they will ding so easilly, and I reckon would look tatty pretty quickly.
If you cant weld, I dont see any reason why you cant just bond normal steel skins on, then fold over the edges. You will have the same result, with a more durable skin and no welding required.
Posted 02 October 2008 - 03:59 AM
I see that you say that you cannot weld but if you can get the skins fitted then take the doors to someone who has a welder and give them a few quid to put the 10mm of weld that is required on each door you would save yourself the hassle of alu skins
just my opinion
michael
Posted 02 October 2008 - 06:52 PM
if one were to be nerdy about it, what is the weight of a normal skin compared to an alu one?
Edited by minidan, 02 October 2008 - 06:53 PM.
