Rebuilt Engine - Really Slow Turning Over
16 replies to this topic
#1 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 28 September 2008 - 06:20 PM
Hi all, jsut built a 1380 engine, all went together fine, it has brandnew pistons and rings.
Engine turned over when out of the car, obviously a little stiff due to new parts and no oil round the engine, ive come to start it and it just seams like the starter motor doesnt have enough power to turn the engine over fast enough,
Any tips anyone?
EDIT: thought i better add Battery is fully charged and start motor is in fully working order
Edited by insamoufonyx, 28 September 2008 - 06:22 PM.
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 28 September 2008 - 07:15 PM
take the spark plugs out and try it then and see what it is like
#3 billyboy83
billyboy83
  • 262 posts
  • Local Club: www.16vminiclub.com
Posted 28 September 2008 - 07:16 PM
Have you primed the oil pump and turn the engine over a couple times with out the plugs in first to get oil round the engine and the pressure up first. also check your timing is set up right and the valves are opening at the right time.
#4 twiglett
twiglett
  • 211 posts
Posted 28 September 2008 - 07:18 PM
check that the alternator turns freely
this happened on mine and i ended up destroying the belt because it kept slippin over the alternator pulley
also if you have a voltmeter check the resistance of the under bonnet earths
i found mine where iether sky high or had an open circuit(break in wire).
#5 Pauly
Pauly
  • 4,213 posts
Posted 28 September 2008 - 07:39 PM
Make sure the battery is fully, fully charged, usualy freshly built engines have a lot of compression so can be difficult to turn over.
Paul.
Edited by Pauly, 28 September 2008 - 07:39 PM.
#6 bigdaddy
bigdaddy
  • 37 posts
  • Local Club: maybe
Posted 28 September 2008 - 07:41 PM
Hi Bud i had this problem a few years ago it was the earth strap .. just a thought
cheers steve
#7 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 28 September 2008 - 07:45 PM
Earth strap i would also say!
#8 mk1leg
mk1leg
  • 9,343 posts
Posted 28 September 2008 - 08:34 PM
hi..If its all new parts then it will take at least 500 miles of running in to be loose enough to spin as every thing is tight so do not over rev or labour in 3rd or 4th gear ................good luck runnung in.................. :P
#9 insamoufonyx
insamoufonyx
  • 1,633 posts
Posted 28 September 2008 - 10:11 PM
Right,
The engine is primed yes, but i dont want to over do it and burn out my alternator or flatten my battery again.
Timing stuff is done following the haynes manual
Battery only jsut came off the charger
Earth strap is fine.
I might try bump starting it as that will turn the engine over a bit quicker, convinced this is the problem as it turns over REALLY REALLY slow
#10 miniboo
miniboo
  • 9,327 posts
Posted 28 September 2008 - 10:49 PM
Did you try it with teh plugs out?
Also mk1leg read this: http://www.mototuneu..._in_secrets.htm
#11 insamoufonyx
insamoufonyx
  • 1,633 posts
Posted 29 September 2008 - 10:55 PM
tryed it without the plugs with no change, gunan bump start it tommorrow, just dont think the starter motor has enough torque to turn the brand new engine over.
Will report back tommorrow eveneing!
#12 miniboo
miniboo
  • 9,327 posts
Posted 30 September 2008 - 12:29 AM
i think there might be something else wrong then, as it should turn over very easily without the plugs in. sounds like soemthing is biding up somewhere.
#13 datsun100a
datsun100a
  • 338 posts
  • Local Club: www.mini-chat.co.uk
Posted 30 September 2008 - 09:14 AM
******************************************** wtp
Edited by datsun100a, 01 October 2008 - 06:54 AM.
#14 mini_kel
mini_kel
  • 2,851 posts
Posted 30 September 2008 - 09:22 AM
when you built the engine did it turn over by hand easy every time you bolted the mains and big ends up?
EDIT forget that just reread the thread!!!
Have you tried a different starter??
Edited by mini_kel, 30 September 2008 - 09:23 AM.
#15 insamoufonyx
insamoufonyx
  • 1,633 posts
Posted 30 September 2008 - 05:16 PM
been talking to some profeshional engine builders today and they have said that its fairly normal and a bump start then run in should sort it out,
Youve gota rember there is no oil around the engine lubricating everything and that its brand new bore, hone, pistons and piston rings, ive been told things are bound to be tight, the pistons were tight before even attaching the crank, i will report back after the bump start, will be tonight or tommorrow
