Little Less Conversation A Little More........
246 replies to this topic
#241 SukiDawg
SukiDawg
  • 304 posts
Posted 20 June 2015 - 11:54 AM
Spent some more time on it yesterday evening. We had intended to mount the mock up engine onto the jig now that the diff is there.
996CDE07-5942-4F84-8E4C-B6C27524CE59_zps
However, when I started checking the shell position relative to the jig - we found that that over the 2 or 3 years with shell sitting up there, it had moved on its supports and was now higher (relative to the jig bed) at the front than at the back by about 10mm.
That needed fixing first then..... We could see that the shell wasn't fully sitting down on the front supports. These fit into the large holes in the engine compartment X-member where the big sub-frame shoulder bolts normally go. The idea of the jig function is that we support the shell there and in the top of the shock mounts at the rear while the whole middle of the car is fabricated. All the floor, roll cage, sill strengthening etc. can be built with the car mounted on the jig like this. When that's complete, we'll make new shell mounts that pick up on the ends of the sills The mounts under the front and back of the car can then be removed in order to make the rear sub-frame and suspension, and also all the stuff that's got to go at the front end.
Front jig mount out and on the deck.
A36E0AE0-EB4B-4E10-946C-A47AEA66FA6E_zps
To fix the issue, I ran the die grinder with an 60 grit drum on the end round the ID of the holes in the shell, and also fitted some bolt plates into the top of the support tubes with M10 nuts welded on the back. This should pull the car down better and prevent any movement.
5D9F4D89-07C7-4F28-BB72-A225AA7BB42B_zps
C3E60229-8D5B-4CD3-A3D7-5355F0DD8731_zps
When we offered it back up and trial bolted the shell down, I expected to maybe have to shim it a little bit under the bottom of the jig mount where it fits onto the base of the jig, but at first attempt it was sitting spot on.
F64FA816-14A6-4214-98EE-DEF34F158002_zps
B9E76BA6-F938-4C26-A9D6-29105E0CCB36_zps
I use a mitutoyo digital level and highly reccomend one as an sound investment! Zero'd off the horizontal base of the jig we were sitting exact on the shell. Although it looks like the level is sitting on some bumps in the x-member surface, several positions around the car all showed <0.5deg. I suspect thats about as good as any shell would ever measure at so I reckon its good to go.
7D5FA4AF-7F9C-4562-810E-7E1292E185D7_zps
We begin to have a look at how usefull all that mucking about on CAD is gonna be or not be!
E029275B-3171-466B-95A0-82A625C2D257_zps
The engine cannot fit far enough back with a standard bulkhead in place.. as we learnt on page one of this thread of course with my old red shell...  :kiss:  I will be trimming a profiled hole out of the existing bulkhead to let the engine come back to the right position. Nice to see something sitting in there, I've been crawling around the floppy sharp horrid front end every time I go in the garage for years.. all to help with this bit. I can't wait to cut the bloomin thing off.
71933E1A-5C1A-4771-992D-6726D77962A1_zps
Turbo is too high here, and I will use an MHI unit rather than a garrett turbo so this photo is just for fun really...
199B9BA8-4A26-4972-85D2-05A0C2DB5DE4_zps
#242 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,739 posts
  • Name: Chris
  • Local Club: None
Posted 04 July 2015 - 05:35 PM
Looking good matey!!
#243 cosi
cosi
  • 78 posts
Posted 10 August 2016 - 07:57 AM
I wonder where this project is up to. Anyone know?
#244 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 10 August 2016 - 01:38 PM
Second that...any updates????
#245 nelley-9
nelley-9
    Starting My Mini Up
  • 1 posts
Posted 09 November 2016 - 01:16 AM
Nice to see you still doing this as iv enjoyed reading through ;-) . I'm starting a clubman front, with front mounted hayabusa and rwd and will start a thread soon as I get stuck in more..
#246 Pat_T
Pat_T
    Just On Tickover
  • 7 posts
Posted 16 November 2018 - 08:45 AM
any updates SukiDawg?
#247 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 17 November 2018 - 07:09 PM
"Last Active Jul 05 2015"
Think this thread may have met its end!
