It varies with different engines I believe, but with most engines, the fuel system uses the diesel as a lubricant as well as fuel, and petrol has no lubrication properties. So if you put petrol in a car that needs diesel as a lubrication you usually induce wear into the fuel components, usually things like the fuel pump. Some cars are more resistant to petrol than others though.
Thanks for explaining that Jammy.
Also Petrol engines normally run much lower compression then Diesel, if you run Petrol in a Diesel engine you stand a chance of Auto Ignition, leading to engine knock and other unwanted side effects.
I guess up to 10% may be okay in older IDI engines, (Stronteum Dog), they behaved differently again, but it's still not recommended in modern Diesel engines.
Dave
Actually I know a bit about diesel engines as it goes. I've been working on them for 25 years or so now and I qualified as an engineer around 20 years ago Lol! I also make bio diesel by reacting used veg. oil with potassium hydroxide and methanol which I run in turbocharged common rail engines as well as my Mitsubishi turbo.
It was just that you made a sweeping statement that is not correct, no offence meant!
Cheers, Si.
Fair play, what do you work on specifically?
I've been at Lubrizol, Delphi Heavy Duty, and now at Ford.
Some may argue that being in the business longer doesn't mean you know everything, but I'm prepared to stand aside.
I was under the impression you should never run Petrol in a Diesel engine as it breaks stuff, lubricating properties, etc. Hence why running modern compression ignition DI engines on Petrol is usually followed by a bit of a rebuild.
Did anyone see, Wayne Rooney, the ugly chav footballer, managed to break down yesterday after filling up with the wrong fuel.
Dave
