H939 Lvw
468 replies to this topic
#376 miniallsort
miniallsort
  • 4,723 posts
Posted 30 July 2007 - 10:14 AM
very nice dom
#377 The Matt
The Matt
  • 17,231 posts
  • Name: Matt
Posted 30 July 2007 - 10:26 AM
Well, at least the Cooper's in safe hands now. Hope you get it sorted ASAP Dom! :-
#378 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 30 July 2007 - 12:10 PM
Rare footage of the lesser spotted Guessworks there! He's managed to elude most camera's up until now :-
#379 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 July 2007 - 06:21 PM
i was stood opposite the end of a trailer to him in Jan this year at a mini show and didnt know it was Guessworks lol.
Nice one dom. have a nice time in scotland too.
#380 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 31 July 2007 - 06:46 PM
Thanks chaps.
Thanks to John (Burt) I have received the metro seat subframes, so will fit those when the Mini returns.
#381 Dom
Dom
  • 10,685 posts
Posted 06 August 2007 - 03:45 PM
When the Mini returns I want to fit the metro seats with the subframes, a couple of power sockets and sound deadening.
Added a page to my website featuring pictures from Southern Mini Days 2007.
edit: This has been since removed and will be added at a later date.
#382 Dom
Dom
  • 10,685 posts
Posted 21 August 2007 - 08:34 AM
I returned home Sunday afternoon at 2 pm after the family holiday in Scotland and on the way back I picked up the Mini from John's.
This is a summary of the work carried out written by John Guessworks.
Engine removed from vehicle, and final drive removed from gearbox, which was already a 3.44 ratio, this was replaced with a 3.1 ratio. The diff cage was stripped and rebuilt with a nearly new compeition diff pin, planet gears and mica thrusts.
New diff output seals, rod seal and gaskets use to reubuld along with 7/17 speedo drive worm and pinion to correct speedo reading. Transfer case was stripped and stripped as there were excessive oil deposits in clutch housing. New primary seal fitted.
Top engine steady bushes replaced with new poly vaiants due to excessive degradation. Top radiator fixing bracket welded back together as it was in 3 pieces.
Completed engine refit with exhaust, thermostat and rocker box gaskets. Oil change using Halfords 20/50 Classic (green) oil, and coolant renewed using 1 ltr antifreeze.
Drive problem diagnosed as failed drivesahft/Inner CV spline connection. Reconditioned Inner CV added, new CV boot and replacement driveshaft.
Exhaust repositioned and rear bracket welded to exhaust to provide stronger support. Middle support raised to bring centre section higher into tunnel reducing risk of catching it on speedhumps.
Rear brakes were checked for adjustment and re-adjusted.
It's so great to have the Mini back. I'm very pleased with it, it drives so much better than previously. As you can see the exhaust looks normal. I filled the tank and calculated my fuel consumption.... 52 mpg total of 182 miles! When I first got the Mini it averaged 40 mpg, the last gearbox averaged 20 mpg and this one is averaging 50 mpg.
It's not all good news though. While John carried out the work he found some issues that need attention.
Excessive corrosion was encountered in the area around the O/S front subframe top turret mount. Corrosion on front valance, N/S and O/S A panels and doors. N/S sill, previously patched, now holes through. O/S rear wheel arch very soft. Front cones very compressed.
#383 Hannioli
Hannioli
  • 1,786 posts
  • Local Club: E.L.M.O & Essex
Posted 21 August 2007 - 06:50 PM
Hooray for you getting your mini back Dom! :thumbsup:
I bet you're really happy! :sneaky:
#384 Dom
Dom
  • 10,685 posts
Posted 27 August 2007 - 06:40 AM
Took a couple of nice shots while helping out Tom.
#385 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 27 August 2007 - 07:13 AM
Looking good dom ;D
Thanks for the help.
#386 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 27 August 2007 - 09:12 AM
Great to have your mini back!
"If u can ...." what's that on the bumper? ....Read this you're too close? Lying drunk in the gutter?
#387 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 27 August 2007 - 12:29 PM
Is it something like "if you can read this well, please wash me?"
#388 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 27 August 2007 - 01:34 PM
Good to see all the work getting done on it Dom. Shame about the body work though, but it happens to us all.
#389 Dom
Dom
  • 10,685 posts
Posted 02 September 2007 - 03:52 PM
Thanks guys. :wub:
I've had the mixture and timing tweaked as it was slightly over on emissions. It doesn't sound as mean now but acceleration has improved.
I added a new page to my website titled "The First Stage" which covered the start of the Brands Hatch to Nurburgring 2007.
edit: The page is no longer there but in the future will be put back online.
#390 D.Cooper
D.Cooper
  • 36 posts
  • Local Club: Mini Club
Posted 03 September 2007 - 03:22 PM
Nice homepage :lol:
