H939 Lvw
468 replies to this topic
#316 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 07 January 2007 - 03:07 PM
Update:
The good. The distributor is now on and working, which means my fuel consumption and power should be back to normal.
The bad. The exhaust is loose again, and is barely hanging on. This is irrating as we put on the new mounts only a few weeks ago.
The future. I'm going to order a new manifold, and exhaust system to fit the car to solve the problem.
#317 Dom
Dom
  • 10,685 posts
Posted 20 January 2007 - 04:43 PM
Purchased stage 2 Maniflow manifold and RCM exhaust. Sounds great and its running nice. B)
#318 *DJH*
*DJH*
  • 4,972 posts
Posted 20 January 2007 - 05:33 PM
Is That A Three Inch Exit There Dom? It's Like A Bazooka :-
#319 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 20 January 2007 - 06:16 PM
no its a domooka :-
#320 *DJH*
*DJH*
  • 4,972 posts
Posted 20 January 2007 - 06:17 PM
:- Boom Boom
#321 Dom
Dom
  • 10,685 posts
Posted 30 January 2007 - 09:40 PM
After a long day lectures 9 till 5 (last week, every monday), I returned to my car to find that a large puddle had formed and the front of my car was in it. I was parked at an angel with the front sloping down. The next morning I discovered that my front left carpet was soaked. I took it out, chucked away the sound proofing as it was destroyed and discovered a small hole. The water from the puddle must have risen and gone into the car during the course of the day.
I also have a mystery water leak. It's coming into the front passenger side at the front and drips down onto the carpet. It isn't the windscreen seal or the scuttle and inside the engine bay there are no holes or visible signs of liquid transfer. It's not the heater matrix either.
I've removed my ICE for now as I want to change a few things as well as sort out the leaks.
#322 Boab
Boab
  • 1,610 posts
  • Local Club: E*S*M*O*C
Posted 31 January 2007 - 12:11 PM
Could it possibly be coming in through the door hinges????? This is where I eventually sourced mine to. Also the window wiper hole????
#323 Dom
Dom
  • 10,685 posts
Posted 06 February 2007 - 03:26 PM
OK. The mystery leak, what could it be?
It’s NOT:Coming from the engine area,
Scuttle,
Windscreen seal,
Windscreen holes,
Door hinges,
It's a long term leak. It's not causing me major problems at the moment, but if I can, I'd like to fix it before I put my dash and stereo back in.
#324 Boab
Boab
  • 1,610 posts
Posted 06 February 2007 - 11:24 PM
Perished heater hoses????????
#325 pinch
pinch
    Das Pingu's
  • 527 posts
Posted 07 February 2007 - 07:09 PM
have a look behind the dash where the fresh air vents come into the car, at the top of the wheelarch, minis rust very well around here!
#326 Boab
Boab
  • 1,610 posts
Posted 07 February 2007 - 08:30 PM
Spot on :wub:
#327 Dom
Dom
  • 10,685 posts
Posted 07 February 2007 - 09:53 PM
I'll have a look, that does sound close to where the water is coming from.
Just a personal note,
I've uploaded my website www.dominicsandiford.co.uk
#328 mini-Ash
mini-Ash
  • 329 posts
  • Local Club: LSMOC
Posted 07 February 2007 - 10:31 PM
Exhaust looks good mate. Some nice pics too.
#329 Dom
Dom
  • 10,685 posts
Posted 17 February 2007 - 05:43 PM
Thanks.
ICE is back in bar the sub and amp, which I'll fit at a later date.
#330 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 17 February 2007 - 06:07 PM
did you find the leak
