Black Smoke?
24 replies to this topic
#16 Big Man
Big Man
    Put your trousers on---You're Nicked!!
  • 1,002 posts
Posted 23 September 2008 - 05:41 PM
Does the Spi need "time" to adjust itselef ECU wise when a sensor has been changed or shold the effect be immediate?
#17 Big Man
Big Man
  • 1,002 posts
Posted 23 September 2008 - 06:02 PM
Could a too big Spark plug gap account for the rich running???
Only ask as I got the NGK and popped them straight in without checking and thinking about it all was well until i serviced my car!!!!!!!
#18 Dasher1275
Dasher1275
  • 48 posts
Posted 23 September 2008 - 08:28 PM
if your plug gap is to big this might make it not burn all the fuel in the chamber and produce black smoke, it would use more fuel as you are useing the throttle more as you have less power
#19 Big Man
Big Man
  • 1,002 posts
Posted 24 September 2008 - 10:22 AM
Will check sprak plug gaps tonight and see how it goes
cheers
bm
#20 Big Man
Big Man
  • 1,002 posts
Posted 27 September 2008 - 03:13 PM
spark plug gap is fine,
This is really really annoying me now and its still drinking fuel!!!!
Tappets re set.
Plugs checked
CTS - Changed (when warm is a needle width below the half way mark- so bang on)
Tick over is approx 850 Rpm when warm and approx 1100 when cold. So think thats okay
No flat spots whatsoever
Drivers very well aprat from black smoke and drinking the fuel!!!
What is it what can I check need any and all suggestions urgently please.
To date I have had a twin DTM fitted and done an oil, oil filter, air filter change and plug change. it went "bad" all of a sudden and as the exhaust and service were done within two days i cant recall which set it off!!!
Oh I have also by passed the MAP sensor (fuel trap) as one of the rubber joints have split so vaccume pipe goes from rear of manifold direct to the ECU missing the fule trap out.
Right thats it please help!!!!!
#21 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 27 September 2008 - 03:22 PM
Faulty lambda sensor?
#22 Big Man
Big Man
  • 1,002 posts
Posted 27 September 2008 - 04:31 PM
am looking at the throttle position sensor and the air intake sensor at the min as according the guro sprocket its next to check on the injection guide then it will be lamda!!! trying to start cheap and work my way up!!
#23 Big Man
Big Man
  • 1,002 posts
Posted 28 September 2008 - 07:41 PM
any more ideas???
bm
#24 1984mini25
1984mini25
  • 8,784 posts
Posted 28 September 2008 - 10:10 PM
You can check the lamber sensor with a voltmeter with it still fitted and plugged in, normally the black (signal) and grey (earth) wires. With the engine up to temp you should see it switching between 0.2 and 0.8 volts.
#25 Big Man
Big Man
  • 1,002 posts
Posted 01 October 2008 - 05:31 AM
Lambda checked as above,
Airt intake sensor changed
Coolant Temp sensor changed
Relay slightly corroded now cleaned
Car running at around 40MPG Happy now
BM
