Black Smoke?
24 replies to this topic
#1 Big Man
Big Man
    Put your trousers on---You're Nicked!!
  • 1,002 posts
Posted 19 September 2008 - 04:58 PM
1992 Cooper
Spi
91000mls
Standard apart form a DTM
Car runs and drives fine, pulls strong and no probs whatsoever.................
Apart from when i put my foot down or rev at a standstill there is BLACK smoke? The back of the car is covered in flecks of black deposits the same as that inside the bore of the DTM.
I have also noticed that my fuel economy is way down approx 40 miles to a tenner and thats driving "A" roads at 55mph!!
Any ideas most welcome
BM
#2 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 19 September 2008 - 05:00 PM
Might be better if you got this moved to the injection section(oooh-errr)
#3 Big Man
Big Man
  • 1,002 posts
Posted 19 September 2008 - 05:06 PM
oops i thought I put it in that however in my haste for help I posted in wrong bit!
#4 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 19 September 2008 - 05:08 PM
Thats a likely story, do you have an alibi?
#5 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 19 September 2008 - 05:10 PM
Definately an overly rich mixture, I'm not sure of the cause, but I'm sure someone who knows will be along soon
David
#6 Big Man
Big Man
  • 1,002 posts
yeah SOG
#7 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 19 September 2008 - 05:12 PM
yeah SOG
Since when has he been a credible witness???? >_<
#8 Big Man
Big Man
  • 1,002 posts
Posted 19 September 2008 - 05:36 PM
[quote name='nomininolife' date='Sep 19 2008, 06:10 PM' post='1148221']
David
I agree but not sure how to go about fixing the problem, hope its something simple and cheap!
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 19 September 2008 - 06:46 PM
Are all the vacuum pipes in good shape? Check the one running from the inlet manifold.
#10 Big Man
Big Man
  • 1,002 posts
Posted 19 September 2008 - 06:51 PM
yes thats fine as only recently re plumbed it in due to rough running, but will re check.
BM
#11 chris_gilly
chris_gilly
  • 571 posts
Posted 19 September 2008 - 07:25 PM
you could by a colourtune around £15 they are....
anyway have you checked the air filter as a dirty on can cause this?!?!
also could a baffle in the exhaust system give way or is the exhaust internals sooty??
#12 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 20 September 2008 - 06:20 PM
When were the valve clearances last set?
#13 Big Man
Big Man
  • 1,002 posts
Posted 21 September 2008 - 03:49 PM
Would the tappets not being set correctly (even thought they are proper quite) account for 20 - 30 miles @ 50 mph "A "roads" to a tenner and shed loads of black smoke???? I have not done the tappets since I owned the car so at least three months.
#14 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 21 September 2008 - 10:19 PM
If their well out then it could be causing you some real problems.
#15 Big Man
Big Man
  • 1,002 posts
Posted 23 September 2008 - 05:09 PM
tappet set yesterday.
Changed the Coolant tempssensor today
Topped everything up and guess what STILL balck smoke and smell RICH
Also put it on the MOT gas analyser thing before CTS change and Co2 was around 10.34 (top left bit of screen) chap said it should be running around 0.4 - 0.5 and said my economy was like 10 x worce tha nwaht it should be.
Im stuck HELP!!!!
BM
