Gear Stick
8 replies to this topic
#1 wakkoboi
wakkoboi
  • 414 posts
Posted 16 September 2008 - 04:16 PM
1985 manual 998
recently bought a KAD quickshift off Wilson1275 on here.
had a brief look at how to fit it tonight but cant see how to get the current gear stick out, there seems to be a round casingwith 2 pins sticking out of it?
Mike
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 16 September 2008 - 04:21 PM
Pull up the carpet, pull off the rubber gear boot and push the cap of the stick down.
If you look at the housing the gearstick goes into a round metal dome, push that down and twist. It's like a light bulb fitting.
#3 wakkoboi
wakkoboi
  • 414 posts
Posted 16 September 2008 - 04:36 PM
ok ive got the casing off and pulled the gear stick out, now any idea how to fit the KAD?
#4 wakkoboi
wakkoboi
  • 414 posts
Posted 16 September 2008 - 04:45 PM
there seems to still be a metal collar type thing with 2 pins sticking out, do i knock the pins out and slide the collar off?
normally i would go for trial and error but need to get to college tomorrow so thought i should probably check first :(
#5 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 16 September 2008 - 04:56 PM
The Kad quickshift will have two screws either side.
These screws screw into the side of the gear stick housing. You should see two suitable looking pins that need to be knocked out. Then the next bit is up to you.
Either try and screw in the two screws directly into the holes and hope they tap their own thread
or
do the job properly take the entire housing out and tap the two holes properly with a proper thread tapper!!!! HOWEVER IIRC the two bolts on the quickshift are M5, if not M5 im almost 100% sure they are a metric thread so you will need a metric thread tapper!!!
#6 mike.
mike.
  • 6,176 posts
Posted 16 September 2008 - 05:00 PM
The threads don't need cutting into the gear housing because the mounting cup on the gearstick itself is threaded. So once the bolts are tightened there not really going to come loose.
#7 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 16 September 2008 - 05:02 PM
Hang on which type of KAD quickshift do you have, rod or remote, early or late style?
Only pic i have im afraid
Edited by Stewart_GT, 16 September 2008 - 05:04 PM.
#8 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 16 September 2008 - 05:46 PM
might i add this is NOT a KAD quickshift!
i sold it as a quickshift, and i was advised to knock the pins out and screw the stainless bolts in until it was secure (i chucked the bolts in as it didn't come with them).
easiest way would have been to remove the whole linkage and do it off of the car mate :thumbs:, and make sure you had plenty of time to do it. never do these things on a time budget!! :craxy:
#9 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 16 September 2008 - 05:52 PM
Ah all is explained now.
As Wilson and I have said you really need to have the housing at the bare minimum dropped down from the tunnel so you can work on it properly! :(
Edited by Stewart_GT, 16 September 2008 - 05:52 PM.
