1993
The drivers window got progressively stiffer over a period of time and eventually 'popped' under a significant amount of arm torque.
I took the old mechanism out and found the teeth in the gears buggered beyond repair. Fine I thought, I'll find one on ebay.
So I replaced the broken winder with a perfectly good newish one and found it seriously difficult as heck to wind the window up. Came down easily though.
It was so hard to wind up I assumed I was doing some damage to something, I pulled the mechanism and sure enough, one of the arm pulley things that guides one of the window runners was warped like all get out. (pic attached).
has anyone had a similar experience? what am I doing wrong? where is the problem? It all seemed quite simple.\
Any help appreciated.
