Right to show that I do actually work on the van every so often I decided to go and get some work done while Andy is away in London for the weekend.
So went over this morning and lifted the engine out.
We will have to finish cleaning under the bonnet now then engine is out.
I then popped the flywheel off which came off really easily I was quite surprised as it doesn't look like the engine has been apart since it was built in 82!
After that I split the engine and box and whipped the centre main cap off so that we can get it machined flat for a centre main strap.
However there is a slight problem as the mains bearings are knackered. So it looks like we will be re-shelling the bottom end.
After that I'd had enough of getting greasy for the day so pulled the van back into the garage and have dropped the clutch and centre cap off for for the lugs to be machined on the back plate and the cap for centre main strap.
Edited by minimadmotorman, 03 October 2009 - 05:21 PM.
