Project 'left Overs'
326 replies to this topic
#286 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 10 May 2011 - 09:37 PM
Nice bit of weight saving there! I use fish weighing scales aswell for weight comprason :)
cant wait to get my turbo on the road now, great project lads.
edit-
Edited by Racer_Pete, 10 May 2011 - 09:41 PM.
#287 apbellamy
apbellamy
  • 1,001 posts
Posted 15 May 2011 - 04:18 PM
Lots of progress this week :)
Benross Racing have nearly finished the head refurb/upgrade, should be a cracker when it's done.
The block has been stripped and drilled for 11 head studs. That'll be getting dropped into Force Racing for new cam bearings tomorrow. There oil fed thrusts have done their job well, the thrusts are near on perfect after a load of abuse on the road and drag strip. :wub: The new rotating assembly will be going for balancing tomorrow too.
The new box is just about done, just need to fit the diff.
New exhaust is nearly sorted.
Got the new turbo butchered onto the metro manifold.
Getting there.
Edited by apbellamy, 15 May 2011 - 04:19 PM.
#288 luke666222
luke666222
  • 158 posts
  • Local Club: Crewes Missiles
Posted 16 May 2011 - 07:27 PM
just read all 20 pages. ace work guys love it!
Edited by luke666222, 16 May 2011 - 07:31 PM.
#289 apbellamy
apbellamy
  • 1,001 posts
Posted 17 May 2011 - 08:09 PM
Some ham fisted sod has snapped the bit of the waste gate arm that holds the actuator arm on (before we got the turbo).
So I've wobbled up a new one.
Turned out OK.
Then we pulled the engine out of my mini, dropped it in the van and shoved a few things on.
Should all fit and work. Actuator will be a bit of a pain though.
#290 apbellamy
apbellamy
  • 1,001 posts
Posted 28 May 2011 - 03:52 PM
Got the oil drain sorted. Not pretty, but it should do the job.
Got the down pipe sorted. All lines up nicely, just needs welding up.
Got the short engine built.
Finished the gearbox
And stuck them together
Benross Racing has also finished the head refurb/upgrade. New guides and 30/36 stainless valves. In comparison to it's original 'Stage 3' porting, the chambers are massive and the ports look great, should be a big improvement. :D
Getting there :)
#291 apbellamy
apbellamy
  • 1,001 posts
Posted 29 May 2011 - 04:19 PM
Got the downpipe welded up.
Noticed a bit of a restriction in the mouth.
So I ground it out a bit
#292 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 29 May 2011 - 04:30 PM
Read through the whole thread, looking great, keep it up :)
#293 apbellamy
apbellamy
  • 1,001 posts
Posted 29 May 2011 - 04:33 PM
#294 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
You sure that Lambda sensor will be alright there? It says they should be 18-20 inches down the downpipe, further if it's turbo'd...
Looking sweet as though, that's a fine looking gearbox!
#295 apbellamy
apbellamy
  • 1,001 posts
Posted 29 May 2011 - 04:50 PM
Thanks.
That's the factory position for the sensor on the SAAB, so it should be OK. I know a few people who have put them into the elbow on the T3 and it's been fine.
If not, I'll have to shift it :)
#296 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 29 May 2011 - 08:55 PM
Fair enough, can't argue with that, I was just going with the AEM instructions.
Will this be making an appearance at MITP? :)
#297 apbellamy
apbellamy
  • 1,001 posts
Posted 30 May 2011 - 08:36 AM
We hope so. We had to ask nicely for permission to run it last year as it's not a mini...
It should be at Avon on the 9th July and is taking part in the 16v Mini Club Annual Sprint the weekend after. Fingers need to be taken out...
#298 apbellamy
apbellamy
  • 1,001 posts
Posted 30 May 2011 - 05:14 PM
It wouldn't be our van with out a rusty hole in the floor come MOT time...
Exhaust and fuel plumbing is sorted. I've shifted the fuel filter out of the way and plumbed it in after the pump.
Got most things slung in place in the engine bay, should all fit OK...
Also whipped the interior out so that John can have the pleasure of chipping of the sound deadening from the floors :P)
#299 apbellamy
apbellamy
  • 1,001 posts
Posted 31 May 2011 - 08:20 PM
Engine
#300 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 01 June 2011 - 12:34 AM
Looks sweeeeeeeeeeeeeeet!
