We're back to probably the slowest metro van in the world
We traced the excessive boost to the cheepo ebay manual boost controller, but the damage was done. The engine's out and partially stripped now.
The main reason was the smoke. Low compression on all 4 pots and smoking pretty much all the time. There where also symptoms of head gasket failure. Turned out the head gasket was fine, but it's looking like the block has sunk between 2 and 3 (third time the head has been of with the same result each time, smoke damage but no burnt fire rings). The cheepo head gasket stood up quite well considering. The thrusts where also concerning us as the rev's where still dropping with a good few miles on it.
*melon* happens. We have a really good condition block (honing still visible and no lip) which will be getting preped, honed and checked for flatness. It will also be taking a trip to Fast Carl for an oil fed thrust conversion. Total seal rings are on order and should be here in a few days.
When it was first on the road, full emergency starts where destroying the engine mounts. The pancake filter was bent from hitting the bulkhead. We don't really want a red hot turbo smashing into the brake pipes. So while I was waiting for John to bring my engine crane over, I broke out the CAD:
Thin steel prototype looks to do the job quite nicely.
Not bad for a first attempt. I'm going to get some thicker steel and make another. The new one will be boxed in between the engine steady bar and the bulkhead side of the bracket. As it is, I think it would just concertina in under any more than normal load.
