Project 'left Overs'
#181
Posted 12 December 2009 - 06:02 PM
#182
Posted 13 December 2009 - 02:58 PM
#183
Posted 14 December 2009 - 09:22 PM
With a good few turns on the mixture screw it runs nicely.
We've put a new relay in for the starter, so now we have control of when the starter runs
Some of the interior is back in and we've made a start butchering the dash for the gauges.
Starting to look like a propper engine bay again
Feels like we're nearly there now.
#184
Posted 14 December 2009 - 09:29 PM
this car combines all the things i love about modified cars well engineered engines in a rat look car that wipes the smile of bmws face
i know thats what i just achieved threw the leeds tunnels
#185
Posted 14 December 2009 - 09:42 PM
Pete.
#186
Posted 18 December 2009 - 02:30 PM
With a little 'loading' from the brakes we managed to produce 0.6bar of boost (8.7psi) before I bottled it as we haven't properly set the mixture.
The dump valve works too!
#187
Posted 28 December 2009 - 05:49 PM
With some fluid through it and a lot of adjustment the clutch works and it moves under it's own power again.
It's not good enough to drive yet, so we need to look into longer/adjustable rods for the slave cylinder to clutch arm.
#188
Posted 28 December 2009 - 07:49 PM
#189
Posted 18 January 2010 - 12:29 PM
#190
Posted 18 January 2010 - 08:36 PM
#191
Posted 18 January 2010 - 09:35 PM
and in this one the crank position sensor
im guesing your going to connect all this up later and then Remove the Coil and Dizzy?
Just wondering are you using a kit or have you canabalised the whole system from another car?
If so id be interested to see how its done as the price for magajolt/storm type systems are soo expensive
Nice to see somebody keeping a Metro on the road
Yes they are a good source of goodies for our minis but if we keep canabilising them there will be non left on our roads anymore
Great Project
#192
Posted 07 March 2010 - 05:11 PM
Today we've been out and done my least favorite job - soldering. I was pleased to see that everything worked first time, which makes a change for me.
The result of this was the megajolt in, working and mapped. Good bye crappy distributor!
I had thought it would be a pain to get the mgajolt wired up and working, but it wasn't it was litteraly join the wires and fire it up.
It's pretty much sorted now, just a few PITA jobs and then it can go for test at the end of the month and all being well be taxed on April 1st. I've typed it now, so I'm commited....
#193
Posted 07 March 2010 - 05:22 PM
Was it hard to map the MJ, or did you load up a map from a similar spec engine?
#194
Posted 07 March 2010 - 05:24 PM
It's a standard metro turbo map of the internet. Just a nice safe one to start with until we can get it on the rollers
#195
