Project 'left Overs'
#166
Posted 22 November 2009 - 09:38 PM
#167
Posted 23 November 2009 - 09:20 AM
It will be even better when it hopefully runs!
LOL
Turns out I'd forgotten to recharge the battery!
Regarding your install - the air filter seems quite close to the turbo - are you going to rig up a cold air feed to the filter so it's not sucking in all the hot underbonnet air? IIRC, the Turbo bonnet had two extra vents due to the extra heat?
#168
Posted 23 November 2009 - 09:30 AM
The air filter position isn't finalised yet. It's just wedged there while we get the cooling system and intercooler pipework finished.
You are also right in saying that the turbo bonnet had 2 vents in the middle. We had these on our turbo bonnet but unfortunately a blow out on the autobahn knackered the bonnet so we are stuck with a standard one for now at least.
#169
Posted 28 November 2009 - 06:19 PM
Got the CPS fitted.
Fitted the boost controller. Kept it inside the engine bay to try and stop us winding the boost up all the time.
And I've done some plumbing.
I didn't allow for the length of the alloy bends when I measured up for the interfooler hoses, so I've got loads of hose and an elbow spare and a 45 degree silicone elbow on order.
All being well it should be running soon
#170
Posted 28 November 2009 - 07:07 PM
#171
Posted 09 December 2009 - 09:53 PM
New bolts welded into the exhaust clamp ( 20 minutes at 200 degrees in the oven for a preheat, just don't tell the wife
Welded spring carriers onto the manifold (bent nails). cut it down to size and got the entire zaust fitted properly. We now have a Chav Cannon poking out the back.
Cable tied the pot joint boots, connected the gear linkage and checked the gears (they all work and we've had the box in bits!!)
Fitted the dizzy properly, wired in the ignition, hooked up the battery and tested for spark. All good.
Put some fresh fuel in and checked the carb didn't leak - it didn't
Crossed fingers and turned the key. It turns over a treat, gets a spark at roughly the right spot, but it won't bloody start >
Kept trying for a little while, got a back fire and some smoke from the ignition wiring. Then the starter started running continually. So we threw the towel in.
It will run at the weekend!!!
#172
Posted 09 December 2009 - 10:58 PM
I know what its like when it doesnt start up first time, gets really frustrating
#173
Posted 09 December 2009 - 11:30 PM
#174
Posted 10 December 2009 - 07:14 AM
#175
Posted 10 December 2009 - 12:38 PM
#176
Posted 10 December 2009 - 12:42 PM
http://www.youtube.c...feature=channel
#177
Posted 10 December 2009 - 07:23 PM
#178
Posted 12 December 2009 - 04:58 PM
#179
Posted 12 December 2009 - 05:12 PM
#180
Posted 12 December 2009 - 05:17 PM
I reckon with about 14psi of boost it should be good for about 140bhp, but I doubt we will wind it up that far..
