After 2 weeks waiting, the intercooler has finally showed up!
It looks a lot bigger in person.
So I got busy and lopped of the bottom rad bracket. It fits like a glove and the aim of the pipes couldn't be any better.
Just mocked up with cable ties at this point, but everything still fits.
The rad fits much closer with one of the extra mounting lugs cut of the i/c
One of the problems with fitting an RS Intercoller is that it gets fowled by the bonnet catch, so you have to remove it. No problems like that here
It came with one of the factory mounting brackets, so I hacked it up and welded it to the body.
It's a nice snug fit, but the rubber bungs allow a litle bit of movement. I also chopped of all the mountings that we aren't using. There's no point carrying all that extra weight around!
I'm going to put brackets on for the original radiator tomorrow, but I think we will look for another rad that will sit along side the i/c. There's just enough clearance for everything, but I would be happier with the rad sat in the recess.
