My Speaker Pod Build
#46
Posted 16 September 2008 - 06:25 PM
#47
Posted 16 September 2008 - 06:31 PM
But it should be fine, my highly scientific method of wiggling a foot around suggested there's plenty of space still.
#48
Posted 16 September 2008 - 07:00 PM
The good news is that ive ordered my pair of JL audio subs and a pair of Rainbow coaxes for a bit of rear fill.
Congrates mate looks a good job.
If you ever need to take them down again put another nut on the other side of the bracket or tack weld it in postion so that it doesnt spin when your trying do the bolt up.
these are the dogs bush oisters (sorry admin)
Edited by jwb_moto, 20 September 2008 - 07:20 PM.
Pitcure containing swearing, please see forum guidelines. Thankyou.
#49
Posted 16 September 2008 - 07:53 PM
Im building some pods at the moment.
but its kind of a two speaker setup on each side, but with seperate chambers.
#50
Posted 16 September 2008 - 08:10 PM
#51
Posted 16 September 2008 - 08:57 PM
#52
Posted 17 September 2008 - 05:31 AM
Some people mix an equal amount of resin and filler to gether and then add both amounts of hardener (some times its called milkshake mix) its a bit easier to apply and give a smoother slightly harder finish.
#53
Posted 17 September 2008 - 05:48 AM
You probably already new that, but i thought i'd add my early morning 2p.
#54
Posted 17 September 2008 - 05:48 PM
#55
Posted 17 September 2008 - 05:57 PM
#56
Posted 19 September 2008 - 08:02 PM
here's a tip...use as little filler as possible. in my opinion, if too much filler is used for these pods, it's not as strong and is prone to possibly crack down the road.Intresting, is there not an easier way then filler? i hate the stuff?
to avoid this, form your pod with a polyester material. rather than applying the fb from the outside, apply it from the inside. this will help retain the original form and prevent any major dips and valleys that would require a large amount of filler.
in the event large amount of filler is needed, it's best to use a fb reinforced filler to prevent any cracks like kitty hair.
Edited by boister77, 19 September 2008 - 08:05 PM.
#57
Posted 21 December 2011 - 03:47 PM
#58
Posted 29 October 2013 - 12:27 PM
look good finished
