Carb Not Fueling Engine.
Posted 22 August 2008 - 12:32 AM
Just built a 1275cc engine to put in my car. Turned it over for oil pressure etc, fine. Went on to fire it up and its sparking but the plugs arent getting fuel. Tried cranking with the leads off and the plugs stayed dry.
If i pour petrol down the carb, it fires and runs for afew seconds as expected.
I have a SPI tank using the pump, which at first i put straight into a inline regulator set to 3.5psi. This began to blow the pipes off, so I t-pieced the inlet to the regulator to the return on the spi tank. Still wasnt fueling.
Tried afew things, different carbs inc HS4, HIF38 and a HIF44. Luck of having 3 carbs not to fuel the engine at all is too unlikely, so i am looking elsewhere. Any ideas?
You can hear the fuel fill the float then stop, so the float is full, its just not drawing it through.
Jordie
Posted 22 August 2008 - 12:38 AM
Posted 22 August 2008 - 05:46 AM
Going to try my mates inlet and HIF44 off his car tonight as we know that works.
Posted 22 August 2008 - 11:12 AM
Surely once the carb float is full, it should try firing using that fuel. Not getting a thing with 3 different carbs, HIF38, HIF44 and a HS4.
Cranking over with the plugs out, theres no vapour coming from the bores.
Cranking with the plugs in, they stay dry.
Jordie
Posted 22 August 2008 - 11:23 AM
Guest_ratty_*
Posted 22 August 2008 - 11:26 AM
Part number from Burton Power FSEFPR009
Then from the low pressure side fit your to bring it down from 6psi to 3psi or adjust the FPR009, but you'd need a pressure gauge
Or fit a low pressure carb fuel pump
Edited by ratty, 22 August 2008 - 11:30 AM.
Posted 22 August 2008 - 11:40 AM
Try pinching off the return line while the engine is cranking and see if that kicks it into life. I think you really need a proper, low pressure fuel pump or a regulator designed to work with a fuel return system.
Tried this. Ill get a metty turbo regulator and try that. Just sold one too, buggar.
That doesnt explain why it doesnt use the float fuel when its full. Surely if the float was full, then it would use that fuel to fire, even if the fuel pressure was too low for it to run after the float emptied. We are getting zilch fuel past the carb.
I will see if i can lend a metro turbo regulator off a local lad to try. If not ill have to order something if that is the problem.
Edited by Jordie, 22 August 2008 - 11:42 AM.
Posted 22 August 2008 - 11:53 AM
Posted 22 August 2008 - 11:54 AM
I also agree that you need a different pump. The cost of a quality regulator is equal to the cost of a Facet pump. I would consider looking at how the SPI pump is connected and what low pressure pump you could fit in its place.
Posted 22 August 2008 - 11:59 AM
Posted 22 August 2008 - 08:05 PM
Posted 23 August 2008 - 12:11 PM
Ditched it all in the end for a set of twin carbs mmmmm
