No Fuel
Posted 20 August 2008 - 03:57 PM
im suddenly having problems with my 93 spi as it seems there is no fuel getting to the engine.
i cant even hear anything like the fuel pump starting when the ignition is on II
it turns over bu does not start
any ideas?
thanks
alex
Posted 20 August 2008 - 05:50 PM
hope this helps
daz
Posted 20 August 2008 - 09:39 PM
thanks
alex
Posted 20 August 2008 - 09:49 PM
then turn the key see if you can hear the fuel pump,
if not pull the wiring plug out and join the 2 wire's togerther with a wire.
there is also a inline fuse behide the air filter housing.
one off them should work .
hope this helps.
Daz
Posted 21 August 2008 - 09:11 AM
thanks
Posted 21 August 2008 - 09:13 AM
i have now tried that and nothing happened any other ideas?
thanks
Sounds like your pump has died. Mine went on my 2000 mpi recently & I had to replace it.
Posted 21 August 2008 - 11:15 AM
Posted 21 August 2008 - 11:32 AM
thanks again
Posted 21 August 2008 - 11:45 AM
Posted 21 August 2008 - 12:40 PM
This post is one I started and finished a while ago when having the same problem on my MPi. For all intents and puropses, the fuel circuit is the same on SPi's and MPi's.
Hope it helps!
Posted 21 August 2008 - 12:53 PM
any ideas?
Posted 21 August 2008 - 02:31 PM
Posted 21 August 2008 - 08:02 PM
i have just tested the plug at the top of the fuel tank with a basic circuit tester and the light inside doesnt seem to light so i think it may be a case of no power is getting to the pump
any ideas?
You'll only get juice to the pump when the engine is running or cranking. Apart from a slight surge on ignition as it pressurises the system. I tested mine by hotwiring the horn connector to the pump connector on the inertia switch, then sat in the car, pressed the horn button to see if it worked. Might sound long winded, but it only means shoving a bit of flex in the positive feed pin to the horn and the other end in the positve feed pin to the pump. Dirty bodge but easy and foolproof!
If it works, then you need to get your test meter out and check continuity from the relay module to the inertia switch. If that's ok, it's looking like a suspect relay pack, which quite often go tits up. Only real way to check the relay is to cut it open, as it's glued shut, then watch the relays move. Sometimes, the contacts just need a clean.
Hope that helps!
Posted 21 August 2008 - 10:01 PM
by the way which side of the inertia switch plug is positive? as i may have just been making a small circuit which does nothing but make a small light go on lol. my curcuit tester is just basically a screw driver with a light inside which tells me when there is a current flowing through the circuit. looks like this:
thanks for all your help so far
Posted 22 August 2008 - 01:12 PM
Personally I wouldn't bother with your electrical screwdriver. You can pick up cheapy test meters for under a tenner which will easily tell you where you have and haven't got volts, how good your earth is and also whether or not there are any breaks in any of your wires. I still say you need to find a away of shoving 12v straight up the loom to the pump from the pump side of the inertia switch (the plug should just come off the bottom of the switch). Then just listen for it whirring away. If it doesn't whirr, then you'r pump is knackered, or it's not earthing properly (black wire on top of the pump should ground to one of the rear light clusters in the boot. Make sure they're all clean and un-crudded).
If it does power up ok under a perm 12v supply, then it's probably a knackered relay module, although in my case, it was a loose connection in the loom.
