Year: 1972
I've been trying to fit a standard horn to my car, as it was missing when I bought it. But I can't get it to work properly.
There are two wires just behind the grille, one purple and one purple and black. According to my Haynes manual, the purple one should go to the fuse box and the purple/black one to the horn push. I've used a multimeter to verify that the purple wire has 12v continually present at the horn end.
I've mounted the horn on the front panel behind the grille, but when I connect the purple wire on its own the horn sounds continuously. Thinking it might be the horn push I tried disconnecting the plug for the stalk, but this has no effect and the horn stays on.
What have I done wrong? I thought that if the horn is earthed directly to the body, perhaps it should be connected to whatever comes back from the switch rather than to a permanent live, but the purple/black wire doesn't show any current when the horn push is pressed and there are no other wires to connect. I'm further confused by the fact that the Haynes diagram doesn't show the horn as being earthed directly, even though it connects to the body of the car.
Edited by whawes, 17 August 2008 - 02:34 PM.
