Flashing My Lights
26 replies to this topic
#1 tobiasnugent
tobiasnugent
  • 763 posts
Posted 13 August 2008 - 04:58 PM
you cant flash your lights unless you have dipped beam on is this the same on all minis ? just to flash you have to click the dipped beam on then flash
its just a large carry on if you see a mini and want to flash them!
#2 5MITHY
5MITHY
  • 218 posts
  • Local Club: Minis n Oatcakes
Posted 13 August 2008 - 05:01 PM
I just flash the stick thingy and it flashes :s
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
No you should be able to flash regardless of whether your lights are on or off.
Pull the stalk back towards you.
Edited by taffy1967, 13 August 2008 - 05:01 PM.
#4 nicksuth
nicksuth
  • 1,631 posts
Posted 13 August 2008 - 05:02 PM
You should be able to flash your headlights (high beam) with your lights switched off. Sounds like a wiring fault?
#5 tobiasnugent
tobiasnugent
  • 763 posts
Posted 13 August 2008 - 05:03 PM
my bloody mini and its wiring faults, the faster my dad re wires it the better!
#6 Q_M
Q_M
  • 233 posts
Posted 13 August 2008 - 05:06 PM
Jesus man get that fixed fast you can't flash at other Minis!
#7 sprintmini
sprintmini
  • 316 posts
Posted 13 August 2008 - 05:13 PM
Your problem will more than likely lie in the actual stalk,it may need cleaning to allow the contacts to touch.
Take the cover off,then the steering wheel,then remove the actual stalks and clean between the plates this will more than likely cure your non flashing lights.
#8 M44K TS
M44K TS
  • 3,104 posts
Posted 13 August 2008 - 05:15 PM
yeah i'd say clean the contact on the stalks too, they're brass and get a covering of dirt on causing them not to work.
#9 tobiasnugent
tobiasnugent
  • 763 posts
Posted 13 August 2008 - 05:30 PM
it flashes if i have the dipped beams on tho D:
#10 M44K TS
M44K TS
  • 3,104 posts
Posted 13 August 2008 - 05:44 PM
are you pushing or pulling the stalk to get it to flash?
#11 ricky_mini
ricky_mini
  • 317 posts
Posted 13 August 2008 - 07:34 PM
yeah, you should even be able to flash with no ignition on :s
does anyone know if the relay operates a different circuit when dipped beams are on? 'because it could just be a relay fault.
#12 tobiasnugent
tobiasnugent
  • 763 posts
Posted 13 August 2008 - 09:40 PM
tried both D:
#13 Jupitus
Jupitus
  • 1,479 posts
  • Local Club: Breathemini
Posted 14 August 2008 - 11:31 AM
Flashing with headlights in the on position the power is sourced to the lights via the blue output from the headlight switch. If you are flashign without the headlights on the power is sourced from the purple wire coming off fuse point 4, ie 2nd fuse down, right hand connection. Does your horn work ok? This is sourced from the same point....
#14 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 14 August 2008 - 01:49 PM
We had loads of trouble with this connection on my friends car, clean up the connector on the fuse box aswell as the spade connector on the wire. Sorted our problem.
#15 tobiasnugent
tobiasnugent
  • 763 posts
Posted 14 August 2008 - 01:56 PM
my horn doesnt work either
were abouts should i be cleaning ?
