Firing Order With Megajolt
#31
Guest_ratty_*
Posted 13 August 2008 - 08:40 PM
Put the vr back the way you had it
Swap Coil A & B around
Put leads on 1>1 2>2 etc
Try it
#32
Posted 13 August 2008 - 08:42 PM
#33
When I had it started and running on 2 cylinders the coil pack was to the plugs at 1342 and with MJ connected. So now I'm going to unplug the MJ, and run it in limp mode with 11,22,33,44 and see what happens.
12v, position 1 on the key I get 12v everywhere but when I'm cranking over, the power cuts to the stereo, fuel pump etc ( think!, well it was earlier) so that would cause the EDIS to have no power when cranking, correct? however, I do have spark when I'm cranking :s
EDIT: no I'm getting 12v all the time, even when cranking.
Edited by Sammy D, 13 August 2008 - 08:56 PM.
#34
Posted 13 August 2008 - 08:44 PM
I'll do that...Been thinking about the firing order issue and if the coil a and b are the wrong way around then the order wont be 1342 hence why changing the leads arround from 1>1 2>2 etc helped
Try it
as soon as I buy another starter motor, as I think I've killed this one as well now!
#35
Posted 13 August 2008 - 10:37 PM
#36
Posted 15 August 2008 - 02:39 AM
So glad it runs! It sounds amazing and the revs pick up so quick!
The rocker cover has some clearance issues though, I'm using the purple 1.5s and a tin cover and they whack the back of the cover causing lots of noise! So I'm going to have to get possibly one of those big square ones.
Thank you for all your help, I couldn't have done it without you!!
Samm
Edited by Sammy D, 15 August 2008 - 02:40 AM.
#37
Guest_ratty_*
Posted 15 August 2008 - 06:06 AM
Edited by ratty, 15 August 2008 - 06:06 AM.
#38
Posted 15 August 2008 - 06:19 AM
#39
Posted 15 August 2008 - 11:18 AM
