'76 VTEC Clubby
#106
Posted 24 April 2006 - 01:38 PM
Musac/DVD
Camera system
Sat Nav
MegaView once MegaSquirt is installed (I've also thought about making up my own GUI)
Integrating the alarm with the camera and GPS system.
Possibly a track system (will show lap times/position on track, etc).
I'm currently trying to figure out a way of getting a translucent LCD for a HUD idea.
#107
Posted 24 April 2006 - 01:53 PM
For your own GUI were you just going to have it PC based?
its easy to connect with MegaSquirt on a PC, I have managed to get the various settings into a simple program, but havent taken it any further. But with all the data you could do things like data logging and stuff.
I was even thinking of a Gear Indicator, or an accurate speed indicator.
For the gears if you know how fast your going you can work out which gear your in from the revs. or if you know which gear your in you can work out how fast your going (which should be as accurate as you can get it, similar to reading direct RPM from the wheel, but without the need for another sensor).
I think with some clifford alarms (and im sure some others) they have a com port on them so you can configure them, but i dont know if you can monitor and do other stuff with them.
Have you looked at the GPIO board for MegaSquirt? I might get one later on and have tons of sensors etc, and devise some software to monitor it all (ok the MS stuff can do it but its no fun) and work out other cool stuff.
#108
Posted 24 April 2006 - 02:04 PM
I've also looked at the idea of data logging, mainly on the GPS side, but data logging the engine recordings sounds like a very good idea. I was looking at a showing rpms for gear changes. So if your in 3rd, there would be a display to show what the revs would be if you changed into 2nd or 4th, not sure how handy this would be though, and one of the last things I'll look into.
Interesting that the Clifford alarms have a COM port, although I was planning on making my own alarm system.
I had the same idea about the screen, been looking for an old PDA to rip apart, so I can see what the screen is like without a backing, didn't know you could get some that already have a removable back, do you have a link? Not a fan of using screens and mirrors, I just don't think I'd have enough control over the image, and I think the design of my custom dash won't make this option a great one.
#109
Posted 24 April 2006 - 02:58 PM
No mirros, just the reflection on the windscreen.
Cant find anything on those laptops at the mo, but i know im not crazy, i have seen them before!!
CliffNet Wizard PC control
There is already log viewer software for viewing the standard logs made by the MS software,
which pretty much does all the different variables. So unless you want to anything other than look at the data then that should work as is, but you have the problem when using custom software for the GUI, but you may be able to make it able to output a log file in the same format.
Wonder what other features could all be intergrated with the system,
once the systems are all done we'll have to compare
When you build you alarm, where you planning on a keyfob?
You can by the RF transmitter and receivers to add to circuits so that could work! I also saw a circuit for a short range RF (433mhz) button transmitter where you had a sensor mounted where ever and you just had to rub the button on the sensor for it to activate a relay, and it was coded so not just any button would work.
Ive got a finger print reader on my computer so i was thinking that would be good for intergrating, something like the car will start but will shut down if it doesnt get the correct figure print within a certain time
#110
Posted 24 April 2006 - 03:20 PM
I had seen those finger print readers, although I want to have remote start, so these two things won't really be compatible. I'll probably have a battery cut off key hidden somewhere as well for when I leave my car in dodgy areas or for a long time. I'll probably just get an RF transitter/keyfob.
#111
Posted 24 April 2006 - 03:32 PM
With the LCD screens i have i know how to flip the image, just with 2 small jumpers, so i will see how well they work with just a reflection on the windscreen (will probably be this weekend, or tonight if i have time).
Have you seen the PDAs with Finger print scanners? I was thinking of have a modern PDA and writing the software for it to read MegaSquirt and other things so you could see the engine information from outside the car, and even tune it without being in the car
#112
Posted 24 April 2006 - 03:41 PM
I was going to make the point of some colours washing out if I was to reflect a screen onto the windscreen, but I think this will be a problem I'll have as well. The only advantage I can think of so far using a backless LCD is this; With the reflected image, you may need to use a tinted film on the windscreen to get a bright enough image, which may pose problems come MOT time. With a backless LCD I intend to have it motorised, so it can go down into the dash when switched off. Also, I believe there is a law about having lights or images reflected on the windscreen or something (from what I've read about HUDs in cars (might just be America)), so this may well affect both of us.
#113
Posted 24 April 2006 - 03:47 PM
Then you only have to glance up.
Or the screen infront of you and clocks in the middle of the dash.
#114
Posted 24 April 2006 - 03:56 PM
#115
Posted 24 April 2006 - 04:57 PM
The one on the front is the screen itself, the one on the back seems to be a blur and darkening filter, but trying to remove would probably break the screen as it is about 2mm thick glass.
Also the back light isnt clear so to see through it you would have to have no backlight so you probably couldnt see whats on the screen unless there was a white car in front on a sunny day.
Also with the screen in its normal horizontal position then you cant see through it,
but as soon as you start to rotate to a vertical position it gets clearer (still blurred)
So the only really way of doing it is the have screen flat on the dash and have some polarised glass over the top.
#116
Posted 24 April 2006 - 07:33 PM
I also know that the HUD windscreen on the Covette is different to a non-HUD one, how I'm not sure, I've just seen that there listed as two different parts, with the HUD one being about $50-70 more.
The screens have a special laminate instead of your standard type. It has a reflective coating on the inside to reflect the display. Standard screens don't work (i know because I fitted one in a 5srs beemer by mistake
Pete
#118
Posted 25 April 2006 - 08:51 AM
Think I'll be now looking at creating a display like your idea, Ed. Probably with the screen sunk into the dash, using a lense or mirror to project the screen forward (away from the windscreen) onto a very thin peice of plastic. This can then be motorised to disappear into the dash when not needed, and it also gets around the problem of not needing to tint the windscreen.
#119
Posted 14 May 2006 - 10:30 PM
LOL
#120
Posted 14 May 2006 - 10:40 PM
