'76 VTEC Clubby
#271
Posted 23 May 2007 - 11:02 AM
#272
Posted 23 May 2007 - 11:03 AM
#273
Posted 23 May 2007 - 11:05 AM
#274
Posted 23 May 2007 - 11:12 AM
Ha ha, yea, thought this might be the case. I have a couple of rose joint bottom arms and had wondered whether a high tensile bolt just supported from the back of the subby would be sufficient, but had planned to go the same way you've done yours!lol, we just welded a plate to hold the other end and stuck a normal bolt through
Tom, I'm hoping to be working on it so much I won't have time to update this project thread!
HOWEVER, I have thought about just working on the main mechanics and stuff, leaving the 'making it look good' phase until after Germini. So the plan may yet change to rat look Vtec for Germini, and then rebuild after to make it a show stopper. Might still incorporate some of the trick bits before Germini though, but my priority is getting the body welded up, getting the subframe done and engine running and then the custom cooling system (with carbon roof!).
#275
Posted 27 May 2007 - 05:32 PM
And what are you doing with that "custom" grille, you mentioned in the early stages...are you doing it like a Dodge Charger idea? (with the headlights hidden behind the slats?).
well good job, I guess, you've seemed to just spend lots of money to me
#276
Posted 27 May 2007 - 07:08 PM
#277
Posted 28 May 2007 - 03:08 PM
Hey!! Don't mock! I moved a piece of paper the other day! Might have been the breeze though....I think the title of this thread should be changed to "restoration by telekenisis"
#278
Posted 28 May 2007 - 03:17 PM
#279
Posted 28 May 2007 - 03:33 PM
#280
Posted 28 May 2007 - 03:35 PM
What the 2009 BH2N?It will be!
Mind you, i can talk. I'm not comming this year
#281
Posted 28 May 2007 - 04:00 PM
#282
Posted 30 May 2007 - 08:57 PM
Also, I think my garage needs a clear up....
#283
Posted 30 May 2007 - 08:59 PM
#284
Posted 30 May 2007 - 09:01 PM
#285
Posted 30 May 2007 - 09:03 PM
