Smiths Rev counter and others
Posted 19 June 2005 - 08:02 PM
As some of you know I'm from Portugal.
I'm just finishing my mini but I do'nt know how co connect the Rev counter, the voltsmeter, the ammeter and the clock.
Can someone help me please?
Posted 19 June 2005 - 10:15 PM
First, how old is your Mini? What year was it built?
Second, what type of instruments are you adding (Smiths, TIM, VDO, other?)
Speaking in the most general terms, late model and aftermarket tachometers are voltage sensing. You connect them to 1) chassis ground, 2) switched +12v supply, 3) the coil (-) terminal, and 4) to the dash wiring circuit for illumination.
Volt meters are very simple. They connect to chassis ground and to a switched +12v supply. They don't draw much current so they can be connected to just about any dash wire that is controlled by the ignition switch. The lamp gets wired to the dash wiring as the tachometer mentioned above.
The clock is similar to the volt gauge, but it must be connected to a non-switched +12v source. The lamp gets wired to the dash wiring as the tachometer mentioned above.
Again, without knowing what gauges you're talking about I can't offer specifics. In general you should consider it a necessity to borrow or buy a volt-meter to locate switched and non-switched connections for your gauges.
Posted 20 June 2005 - 06:16 AM
All the gauges are smiths but the clock that'sveglia. My car is a 1980 mini 1000 with a 1974 - 1275 engine. The rev only has one connection to be made?
What kind and thickness of whire should I use?
I was told the volt-meter should be connected to the alternator, is this correct?
Posted 20 June 2005 - 12:15 PM
Please look at the face of your Smiths tachometer for model identification and tell us whether it is marked "RVI" or "RVC". Regardless of type, the color codes for the Smiths tach will be different from those I listed earlier. The RVI tachometers are wired in series with the power to the ignition coil (two wires) while the RVC are voltage sensing and use a single wire connection to coil (-) as I mentioned earlier. Let us know which type you have.
Are you sure you mean "volt meter"... not "ammeter" ? A volt meter will have a scale from something like 10 to 16 volts. An ammeter will have a scale marked something like -30 to +30 Amps with the needle resting in the middle, near zero. A volt meter can be connected to any switched 12v source and it is not necessary to run a wire to the alternator.
Posted 20 June 2005 - 01:03 PM
Posted 20 June 2005 - 04:29 PM
Posted 20 June 2005 - 11:31 PM
I'm fitting an Ammeter and a volt-meter.
The tacho has 2 connections in the back and something like a spike with a round end.
Posted 21 June 2005 - 08:42 AM
It would be best if you could stick up a photo but the two Lucar blade terminals are probably supply and ground, and the bullet is the sensing wire (coil negative). There should also be a bulbholder fitting which will need wiring in.
Posted 21 June 2005 - 09:18 AM
Posted 21 June 2005 - 09:29 AM
Posted 21 June 2005 - 11:52 AM
http://www.mgcars.or...dy_rvc1410.html
Is that the back of your tachometer (or similar)? As Dan said, the "round" spade lug is the coil (-) connection, the flat spade lug is for switched +12v and the case needs a good ground connection.
You also said that you're fitting an ammeter AND a volt meter. Why? Frankly, ammeters are somewhat dangerous in a car with a decent alternator. The volt meter is safer and can generally tell you as much information. I'd choose one or the other, not both.
Posted 21 June 2005 - 08:48 PM
The big hole needs a bulb holder fitted into it for night illumination which will need to be wired into the light circuit.
Posted 22 June 2005 - 12:28 AM
What if I connect to one of the light bulb wire?
Posted 22 June 2005 - 12:06 PM
Make a test lamp. Take a light bulb (like from a turn signal) and attach a length of wire to its brass shell. Then wrap the connection with tape to insulate it. Leave the center contact tip of the bulb exposed. Strip about 10mm of insulation from the "other" end of the wire attached to the bulb. Go to you car's fuse box and look for connections with "green" wires. Touch the stripped end of the test lamp wire to the fuse box terminal for one of these wires, then touch the center tip of the test lamp to chassis ground (like the metal part of the alternator housing). The lamp should be OFF. Have an assistant turn on the car's ignition and repeat your test. The lamp should be ON.
Make your "switched" connection to a terminal that is OFF with the ignition turned off and ON when the ignition is on. Be sure to put inline fuses on the wires to all your instruments.
I'm not trying to be insulting... but if you aren't sure how to find a +12v supply for your gauges... it would be best to NOT use that ammeter. Ammeter wiring is much more dangerous than the simple voltage connections necessary for clocks, volt meters, and tachometers.
