Iron Puzzle & Fish & Chips
#346
Posted 06 July 2010 - 07:54 AM
The Momos. Oh well... I think I keep them save & dry in my room to look at them. They'r too good to be wasted on a daily driver Actually; I'm on the hunt for another set of 5.75" Momos
Cheers,
Jan
#347
Posted 09 July 2010 - 09:16 AM
Yes, I know the lights cluster isn't straight...
Cheers,
Jan
#348
Posted 17 July 2010 - 02:26 PM
On of over 2000
#349
Posted 17 July 2010 - 02:29 PM
Nice work as usual, what's next to come?
#350
Posted 17 July 2010 - 05:27 PM
What' next... Good question. Maybe I finaly change the slipping clutch. I really should do. It's just 3 weeks left for RingOneZero and the Nürburgring o0 A slipping clutch can't be good on the Nordschleife...
#351
Posted 17 July 2010 - 05:48 PM
& good plan, how's the caravan coming along?
#352
Posted 18 July 2010 - 04:08 PM
Obviously not pretty. Inlets are OK, but the exhaust rockers are sitting realy bad on the valve stem...
Which is no wonder when you compare them to the 1275 folded rockers:
Top: smal bore rockers
Bottom: big bore rockers.
The difference is a much wider pad on the tip, which can make up for the big bore's larger valve spacing! On a big bore head the exhaust valves are a bit further away from the inlet valves. With the big bore rocker' wider pad, it looks much better:
Since the rocker shaft was still OK, I was able to fit the new rockers without touching the head nuts and removing the rocker posts. So no risk of ruining the head gasket.
Though if you want to change the rocker shaft - you need to either remove the engine mount & steadys and lower & tilt the engine a bit so the shaft can slide into one of the cutouts behind the rad (about 10mm in each direction).
#353
Posted 18 July 2010 - 05:56 PM
One question, how did you remove the rocker shaft.
I tried this and even when loosening off the tappet adjusters all the way the valve springs where still being compressed and so I couldn't remove the rocker shaft. Could it have been because of the kent 286 cam that was fitted.
Anyway, great work, any news on the accident damage?
#354
Posted 18 July 2010 - 07:10 PM
Though I'm sure you could make a tool to compress two or three valve springs for the process.
I'm sending the accident report to my opponent's insurance - and hope they pay me out (I think they will/need too since it's totaly not my fault).
#355
Posted 19 July 2010 - 07:09 PM
Oh what a pleasantly familiar picture
Though the clutch had less oil in it than I was hoping for
Probably invisible in the picture, but there was only a veeery slight film of oil on the pressure plate. I guess that was just too much for a strong 1275. Anyway, I hope the parts arrive tomorrow nad I can crack on. And hopefully I'm able to borrow the clutch seal tool tomorrow too. I'm not doing it again without a proper protection sleeve.
Cheers,
Jan
#356
Posted 21 July 2010 - 05:00 PM
I mean - it's only the screws holding the flywheel on, they don't need to be good or high tensile or something like that... At least the extracting tool didn't break and I got the remains of the bolt out. But it's still hot - so I leave it for today... Should've never started, I knew it was going to end in (near-)disaster... And I was in no good mood anyway. Well, tomorrow is another day...
Well, at least my improvised clutch oil seal tool did work almost as expected. I'll see if this seal finaly hold all the oil back...
Next evo of that will see some sort of teflon extension on the front to treat the oil seal with a bit more care Can you guess what it is made of?
Cheers,
Jan
#357
Posted 21 July 2010 - 05:07 PM
Cheers,
Jan
and old hub? a lock tab and some wood
#358
Posted 21 July 2010 - 05:08 PM
#359
Posted 21 July 2010 - 05:17 PM
#360
Posted 26 July 2010 - 04:27 PM
BACK ON THE ROAD!! Woohooo! And FINALY the clutch doesn't slip anymore!! And that's SO nice. No more overtaking without knowing wheter you can accelerate or not
Everything works fine now, I'm realy chuffed. Full throttle from 1st to 4th - and no sign of slippage.
The only downer ist the noise... I somehow managed to get the RC40 to seal properly... It's anoyingly quiet now
Cheers,
Jan
Edited by Asphalt, 26 July 2010 - 04:32 PM.
