where did you get you excellent bracket????
Connections
Posted 18 July 2009 - 08:35 PM
Posted 18 July 2009 - 08:37 PM
Connections
Posted 18 July 2009 - 08:51 PM
And I just happen to know them connections
Edited by Asphalt, 18 July 2009 - 08:52 PM.
Posted 19 July 2009 - 04:15 PM
Edited by Asphalt, 19 July 2009 - 04:16 PM.
Posted 19 July 2009 - 06:00 PM
Cam followers have them in stock Bern is not farWhat do U mean?
You never stop discovering new stuff:
I have several clutch covers here. The following two are both A+ clutch covers, both have the same number: DAM5202. But one has a rubber plug in the starter's dome and removable cover for flywheel based ignition timing... It's from a very early 998 A+ engine. Those were partialy A- and A+ engines, had a verto clutch but with pre-verto ring gear and starter. And, as I discovered (hoho!) a mixed clutch cover.
The next thing is the water pump removed from the engine... I've never seen anything like this before... It has a plastic impeller! All others I've seen had cast impellers. Seemed to work fine; but I've heared some storys from VW owners with mysterious overheating problems which couldn't be solved... 'Till they fond out that theplastic mpellor of the pump separated itself from the shaft and didn't spin over a certain RPM range.
The new pump is something special as well: it can be used with or without a bypass. It's supplied with a brass spout and a grubscrew.
But the best part of it is the machined gasket face! I think that's far supperior to the rounded gasket faces you usualy get with new pumps (at least I've never got others).
Another very usefull replacement part for SPI engines is this:
The SPI's oil pipe is just stuck into the block and sealed with a sealing ring & sleeve nut. I never got it to seal properly, regardless of what I'm doing. This braided hose should help getting it to seal like the old banjo bolts (pre-SPI) did. Wasn't cheap, but I thinks it will be worth the money.
The 'hotest' standard cam: MG Metro. If you compare data, you see that it is very close to the Kent MD266!
RED: MG Metro, RSP Coopers, Metro GTA
BLUE: Kent MD266
Checking height @ lobe: 0.017" | 0.016"
Timing (IN/EX): 16/56 59/29 | 24/56 61/29
Nominal lobe lift (IN/EX): 0.263" / 0.263" | 0.263" / 0.268"
Duration (IN/EX): 252 / 268° | 260 / 270°
Lobe centre angle (IN/EX): 110 / 105 | 106 / 106
Lobe separation angle: 107.5 | 106.0
Lift on overlap: 0.054" | 0.054"
But if you campare prices for a new brandnew cam... The MD266 cam is much cheaper! But from what I've read here, the MD266 is generaly accepted as a good allround daily runner cam which gives decent torque. I got the MG cam in exchange for the old - so it's quasi for free
And adjusted the idler gear today. The old one was still pretty good, but I decided to get a other gear with lower mileage. So good to have a couple of shims, again on a exchange-base. I got a few, take those I need and send them back, together with my old ones. New shims are fu... freakin expensive
Adjusted to 0.15mm, I think that's not too tight and not too much.
The final gear's crown wheel is in a local garage to pull the bearing, as my puller didn't grip and I couldn't get the thing to move, not with my puller, not with a crow bar.
Oh, and I forgott to order cam followers... The old ones were pitted badly and I'm fitting a new cam so needed them anyways... Hope they arrive on tuesday, no local garage had any in stock So the only thing I could do to the engine was fitting new big end bearings.
Cheers,
Jan
Posted 20 July 2009 - 08:25 AM
Posted 25 July 2009 - 03:55 PM
Posted 25 July 2009 - 06:59 PM
Posted 25 July 2009 - 07:08 PM
Didn't like that as I was scrolling down, but with the bits and bobs back in it looks quality, really like that.
Spraying anything else with the wrinkle paint?
Posted 28 July 2009 - 12:11 AM
Posted 28 July 2009 - 04:39 PM
This is one of the projects i love. There's just something about it that makes it easy and enjoyable to read. The grammar is better than many of our own country's grammar and you come from Germany i beleive? All the pictures are a nice quality and a nice size, and everything is professionally and clearly explained. If people laid their project threads out like you did, their would be more worth reading.
Keep up the good work,
Jono .
Posted 01 August 2009 - 02:54 PM
Edited by Asphalt, 01 August 2009 - 02:56 PM.
Posted 04 August 2009 - 05:33 PM
