Could you not use a standard Mini airbox? They have a pickup on that side.
Or is it a case of too hard to get hold of over there?
Yes and no... On a std. box the inlet hole is too tiny, thought... With the Cooper/MG Metro's airbox you have an almost 4x(!) larger opening facing towards the airfilter which in turn means you get much more effective filter surface you can use in first instance... The air stream entering the box is larger spread and doesn't have to go long 'twisted' ways to enter 'round the filter. Sorry, I'm not good in explaining that in english - hope you get my idea anyways?
The best std. air filter case is, IMO the old MK1 one (made of metal).
David Vizard rates it as the best ever produced
- but I don't like, as said, that it sucks air from the rad surface in a Mini enginebay with side mounted radiator...
You get burried under standard airboxes if you ask for one
So basicaly: I don't want to use a std. airbox
Head studs arrived, head bolted to engine, valve clearances set - still no speedo gear
But I'm halfways on the verge to just plug the hole and use GPS or rev counter 'till I have a 16 teeth gear to drive a propper speedo...
Oh, and I had to remove the diff side cover for the third time - I misscalculated the thickness of required shims for the bearing's preload
Edited by Asphalt, 05 June 2009 - 02:12 PM.
