Japanese Cylinder Head Transplant.....
cradley-heathen
, Aug 09 2008 12:44 PM
272 replies to this topic
#76
Posted 17 August 2008 - 01:51 PM
proton make a 12valve 4cylinder ugly thing. is it??
#77
Posted 17 August 2008 - 02:57 PM
put my five pence worth in.
the head is not as long as the mini block its also not as wide this would lead one to think it be motorcycle.
I can see more problems with this head.
#78
Posted 17 August 2008 - 02:59 PM
i know that a fiat 16v is the easiest to do....
#79
Posted 17 August 2008 - 03:04 PM
yer the stilo 500 i think should fit dont quote me on that.
#80
Posted 17 August 2008 - 04:51 PM
if you go to the website in my sig then you can see a running Fiat head conversion that is ruuning on propane!!
#81
Posted 17 August 2008 - 06:31 PM
It looks like a Honda engine, I done a head gasket on a lot of years ago. If I am correct in guessing Honda you may find a gasket for the head easier than you think. The same engine was used in other makes of car.
#82
Posted 17 August 2008 - 07:27 PM
Is it a toyota starlet engine??
I found that th 1E engine is 999cc 12 valve sinle cam but its carb'd. The 2E engine is 1.3 (1295-1296cc) 12 valve single cam and came with carb or injection.
please tell me i'm right
#83
Posted 17 August 2008 - 07:37 PM
Ohhh i reckon you might have it austinmini25.
#84
Posted 17 August 2008 - 08:14 PM
Its just the valves that trigger something in my brain.
the_valves_on_the_early_carb_version.jpg 77.13K 30 downloads
#85
Posted 17 August 2008 - 08:27 PM
unless i missed it no one has mentioned the correct manufacturer yet, its also not a bike head either. the head is shorter than the a series one, but it is equally as wide, however the head will be mounted slighly to the front of the block so it will over hang the front, and leave a gap at the back, exposing the redundant push rod holes, which i will plug.
here is a pic of how the valve gear works, clever, and a nice colour too!
Edited by cradley-heathen, 17 August 2008 - 08:27 PM.
#87
Posted 17 August 2008 - 08:39 PM
a pic of the head as viewed from the front (as it will be in the mini anyway) and a pic of the other bits i needed from the engine. there are a bunch of pulleys which i will pick from for my fan belt, and there is also i natty little crank sensor disc should i ever need it if i was to ditch the dizzy and convert to a stand alone ignition system.
Posted 17 August 2008 - 08:50 PM
this is the car will be going into (the red one) and the green one is my dads (my brother is building a screaming engine for that one as we speak)
Posted 17 August 2008 - 09:23 PM
Is that one under wraps aswell
#90
Posted 18 August 2008 - 08:12 AM
Interesting project! good luck.
My guess - Subaru Justy
