Japanese Cylinder Head Transplant.....
#61
Posted 16 August 2008 - 07:28 PM
ALl i can find is 3 cylibder 1 litre 12 valve engines.
#62
Posted 16 August 2008 - 07:37 PM
#63
Posted 16 August 2008 - 07:41 PM
#64
Posted 16 August 2008 - 07:42 PM
#65
Posted 16 August 2008 - 07:48 PM
Surely the more people who knwo the more people can help........
as above
#66
Posted 16 August 2008 - 08:17 PM
#67
Posted 16 August 2008 - 08:26 PM
i appreciate what your saying lads, but there is nothing i need help with, unless you have a 998 block i can have cheap? im not being miserabel with the details, its just whenever i ask people if i can have info on thier projects they dont want to tell me anything! i wanted to measure a crank pulley that a certain mini specialist had for sale for use on a supercharged a series, and they flat refused to let me put a vernier on it to measure the outside diameter.
Just 'cause others are tw*ts there's no need to join them!!!! I've read this thread but am now getting bored with it as I can't identify with the engineering as I don't know what you are working with. Secrecy is for the envelope pushing racers but the rest of us should help each other out and share the knowledge. You sound like a clever chap and I'm sure there are many on here that could learn from you if you would spill the beans!
#68
Posted 16 August 2008 - 08:35 PM
im sorry you feel that way mate, but what will it help you if i tell you what car its from?
its an alloy 8 port cylinder head with 12 valves and one cam. the cam pushes rocker arms instaed of operating the valves directly. the rocker arms on the inlet side are effectively 2 rocker arms "siamesed" together, so the 2 inlet valves open together. i will post some pics of the rocker arms lter so you can see the valve gear. its so simple i dont know why i have never seen this done on another engine. its makes a much smaller head and much simpler to work on. i hope this helps, and i hope you appreciate my discretion.
#69
Posted 16 August 2008 - 09:08 PM
I would suggest getting a belt drive timing setup and using that, you can work out the cog/wheel needed for the cam belt drive.
That tyope of cam/rocker combo is used on the BINI i think.
#70
Posted 16 August 2008 - 09:09 PM
[/quote]
I think Honda used siamesed rockers on some bike engines, maybe XL's but not sure. And as I said it would be easier to identify with what you are doing out of interest if we new what you are working on. I think it is better to share information amongst like minded individuals, even the likes of Vizard collaborates with others re. R&D! I'm sure you are very learned but you never now what avenue might be presented by some others lateral thinking now do you?
#71
Posted 16 August 2008 - 09:13 PM
Hmmm this sounds very familiar, im sure one of the lads at Mini Sport was stripping down a cylinder head of very similar descriptions the end of last week when i was working in there and im sure it was off a KIA....
Edited by Southy, 16 August 2008 - 09:14 PM.
#72
Posted 16 August 2008 - 09:18 PM
Kia, they make drinks don't they?!!!!
#73
Posted 16 August 2008 - 09:32 PM
#74
Posted 16 August 2008 - 09:42 PM
Kia isn't japanese either is it?
Shhhh ive only just found that out myself
#75
Posted 16 August 2008 - 09:59 PM
9 user(s) are reading this topic
0 members, 9 guests, 0 anonymous users
