personally i dont think they are worth spending £800 on then. minispares aus +120 thou (67.6mm) pistons are cheaper and maching a small dish and some fly cuts for the pistons will work out at least half the price if not more
http://www.minisport...au/prod1094.htm
with the shipping it looks like they work out at about £100!!!!!! for a set
^^^^got it in one^^^^ You'd regret spending £800 on pistons!!
phone derek chin, they'll be able to put you intouch with someone who will make you a set for about £400
hold your horses man, i didnt say i was having a set made! the whole project wont cost £800! never mind a set of pistons!
i have had a slight re-think in the build process and i think i have come up with a way of not messing about with valve cut-outs, or dished pistons, and if this works, then this will change the whole scheme of things, it will be much more like a bolt on process which will be better for me and for anyone wanting to do the same later on....
Have a deeper block?
a deeper head, the combustion chambers are REALLY shallow, so in theory i could have a really thick spacer like the jonspeed kit for lowering the compression ration for use with a super charger, but that would need 2 head gaskets which i dont fancy, however i think i can come up with a way of doint it differently, its so obvious i dont know why i didnt do this in the first place!
now im only thinking out loud here so nobody shoot me down, but as long as i can afford to have a good thickness of "spacer" over 5 mm for example i can cut an alloy plate matching the bottom of the head, and tig weld it around the chambers and around the edge of the head, then have it skimmed again to get it flush, at 5mm (aprox) that would see my valves clear of the pistons, and the block (which would mean my previous pocketing of the block was pointless but nevermind!) and the compression ratio restored to normal instaed of 10000000:1 lol
however last night i did go for a drive in the car and whilst pondering it all i couldn't help but think i should just turbo it now and go thwe whole hog......?
calm down cradley.... calm down.... one step at a time!
