Hey
Radious Arms ??
Whats the best way to remove the pinion bushes and bearings ??
Work as a mechanic at a Morgan dealer soo have the tools and equitment to do them jus wondered what the best way off doing them was
Help kindley recived
Thnks, Steve
Radius Arms
themorganguy
, Aug 01 2008 06:56 PM
3 replies to this topic
Posted 01 August 2008 - 06:56 PM
Posted 01 August 2008 - 07:24 PM
If you have the tools the best way would be with a hydraulic internal bearing puller. If you don't have the tools, use a drift.
Posted 01 August 2008 - 08:24 PM
I done mine with one of those one ended hacksaws, and cut down through the bearing and then knocked a screw driver down behind it and levered is out, no risk of damaging radius arm it is solid. Have a look at this www.eunos.com/keith/mini/files/radius_arm_short.pdf , he uses a similar approach.
Posted 02 August 2008 - 11:43 AM
The puller is the best choice, but the most common DIY method is the hacksaw. I chose a third method when I did mine. I made a piece that would just catch the lip of the bearing/bushing and used my slide hammer to pull them out.
I assume you know that when you put the new parts in you'll need to ream the bushing to size.
