Inner Cv Boot Query
6 replies to this topic
#1 padnic
padnic
  • 271 posts
Posted 26 July 2008 - 07:50 PM
I was wondering if someone can tell me if this is right??
I took my drive shafts to a garage beside work today to have the inner and out cv boot changed. The mechanic fitted to inner cv boot with the cable tie inside the rubber (see picture) should it be the same as the outer one i.e the cable tie on the outside of the rubber?? The pictures explain better than i can
Posted Image Posted Image
#2 marsy
marsy
  • 374 posts
Posted 26 July 2008 - 08:11 PM
the inner cv should be cable tied inside the rubber gaitor, so no not the same as the outer gaitor
Edited by marsy, 26 July 2008 - 08:12 PM.
#3 padnic
padnic
  • 271 posts
Posted 26 July 2008 - 08:24 PM
ok great thanks
#4 il-barba
il-barba
  • 839 posts
  • Local Club: malta mini
Posted 27 July 2008 - 08:31 AM
is there any particular reason for this, or can you do them with the cable tie on the outsude?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 July 2008 - 12:22 AM
Because they are not tied to the shaft, they are tied internally to the joint itself. Meaning the shaft can come out of the pot joint and leave it intact and closed when you need to pull the drive shafts out for work on the brakes or suspension.
#6 burnerking
burnerking
  • 173 posts
Posted 28 July 2008 - 04:54 PM
How do you get to the outer CV boot ?
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 July 2008 - 12:04 AM
I don't really understand the question. It's right there, you just grab hold of it.
