Fuel Gauge Not Working
Posted 24 July 2008 - 09:54 AM
Posted 24 July 2008 - 10:10 AM
First of all, have you checked the wires are all connected on the fuel gauge itself in the boot? take them off and clean the contacts, could be a loose connection.
Posted 24 July 2008 - 11:03 AM
Posted 24 July 2008 - 11:13 AM
Posted 24 July 2008 - 12:38 PM
Take a length of wire and strip both ends back a bit. Turn on the car's ignition and use this jumper wire between the green/black wire on the sending unit and the (-) terminal of the battery. Watch the gauge. If it goes to full, your gauge has power and is working.
If the jumper wire fails to make the gauge go to full, the fuel gauge, power to the fuel gauge, or the green/black wire are at fault. You did not mention if the temperature gauge is working or not. If neither the fuel NOR the temperature gauge are working, neither is getting power from the voltage stabilizer. If this is true, let us know and we'll walk you through this issue.
If the fuel gauge appears to be working with the jumper, move the jumper wire to the BLACK wire on the sending unit and use a bent wire (coat hanger or similar) through the tank's filler neck to lift and lower the float arm. Watch the gauge as you do this. If the gauge works now, run a new black wire to a good earthing point in the boot. If the sending unit still does not work, consider replacing the sending unit.
Posted 24 July 2008 - 12:48 PM
I have a similar fault, i recently changed my spi engine to a carb engine, i am running the ignition side of things from the ecu and the fuelling side to the carb! works lovely apart from the fact that the fuel gauge and temperature gauge have stopped working! You mentioned something about a voltage stabiliser if both fail.
Dave
Posted 24 July 2008 - 05:54 PM
Posted 25 July 2008 - 12:07 PM
Dave, you asked about your gauge problem after an engine conversion. Sorry... your car is too new for me to make any knowledgeable comments. However, since both your fuel and temperature gauges are not working, this points to a supply problem. You voltage stabilizer may have failed or you may have disturbed/damaged/broken the switched 12V supply to the stabilizer. Others with knowledge of the later cars will have to advise you concerning where to check these things.
Posted 25 July 2013 - 08:52 AM
Hi,
I also have a simular problem, my temperature gauge dosent work at all (as far as im aware)
But my fuel gauge works but when i fill the tank it says i have half a tank?
Posted 27 July 2013 - 11:31 AM
The two gauge problems may or may not be related.
On carbureted Minis the temperature sending unit is on the cylinder head just above/behind the alternator. Locate the sending unit and unplug its wire. Turn the ignition key to the run position so that the ignition warning light is on. Have an assistant hold the metal terminal on the disconnected temperature sender wire to a bare metal place on the engine. I suggest a bare metal spot on the alternator. Watch the temperature gauge and see if it goes to "HOT". If it does, the sending unit is bad. If the gauge remains "cold" then the problem could be the gauge or the sending unit wire is cut/broken. If the gauge only rises to "1/2" or "normal" (like you mentioned for the fuel gauge above) it is likely to be a problem with the voltage stabilizer.
Repeat this test in the boot for the fuel sending unit. Unplug the green/black wire from the sender and touch it to an earthing spot while the ignition is on. If the gauge goes to "FULL" the problem is the sending unit. If the gauge only goes to 1/2 as you mentioned above, that could be the voltage stabilizer or the gauge itself.
Posted 27 July 2013 - 04:21 PM
You can also check the sender unit by placing a multimeter on the continuity setting. one lead on the body of the sender the other on the terminal, by moving the float up and down either with it removed or with a coat hanger inside should alter the reading. If it keeps reading 1 then this is an open circuit and is probably had it. If this is working then there are great comments above.
Posted 23 July 2020 - 07:25 PM
Posted 23 July 2020 - 07:35 PM
If the tank has been emptied check that the sender hasn't got stuck against the side of the tank - I had that happen to me.
Posted 23 July 2020 - 07:40 PM
Posted 24 July 2020 - 08:07 AM
