1962 Mk1 Rebuild
#16
Posted 30 September 2008 - 04:54 PM
#17
Posted 30 September 2008 - 09:39 PM
I have been quoted $750 to do the outside with plastic blasting. I am going to get a quote for soda blasting today as well hopefully
Sounds good. I'd go for it. Stripping the car down by hand will cost you far more in time, materials, and frustration.
#18
Posted 30 September 2008 - 09:43 PM
Wheres the EX hinges?<_>
#19
Posted 30 September 2008 - 09:52 PM
Looks really good mate!
Laying in a heap of old parts! I'll definitely be fitting external door hinges though. As I said earlier, I really want the car to look close to original. At this point, I don't even plan on running fender flares if I can get away with it!
And thank you for the encouragement.
#20
Posted 30 September 2008 - 10:06 PM
#21
Posted 30 September 2008 - 10:14 PM
I dropped the car off at the rollcage fabricators last week. Beyond just the standard cage, I'm having them tie into the suspension mounting points front and rear. This should aid handling and feel. And of course, it's also a safety measure. Lots of pics when I get the car back in a couple weeks.
Now on to the parts that have shown up:
I pressed the bearings into the hubs - not a big deal, but something I'd actually never done before. Next time I think I'll use a press!
KAD makes some nice stuff! MiniSport too - that's their alloy swivel hub and drive flange.
And what problems have I run into? I found 4 things that didn't fit:
1. MiniSport alloy drive flanges - the holes for the brake rotor retainer bolts were too small! I drilled them out a bit and all is fine.
2. Revolution 10x5 wheels - the holes for the lug nuts were too small as well, but only on 1 of the 4 wheels. Strange. I have carefully drilled them out slightly also.
3. Mintex front brake pads won't seat in the front calipers completely as they conflict with the supplied caliper spacer bushes. No biggie though - just 5 seconds on the grinder and they slid in.
4. The Pro-Tech coilovers are made to mount to a 3/8" spindle on the rear swinging arms, but I spec'd these KAD units with 1/2" spindles for added strength. I thought I could just pick up larger ID bushes but I've had a difficult time locating some on the Net. Also, my email directly to Pro-Tech has gone unanswered so I think I'll just try to bore these out to the correct size.
So just a few minor setbacks, nothing huge. Of course the project has a long way to go yet...
Edited by Joe250, 05 July 2014 - 11:54 PM.
#22
Posted 30 September 2008 - 10:19 PM
well done so far fella
#23
Posted 30 September 2008 - 10:39 PM
its comming on arealy well keeps pics comming......................
Thanks, leg. Should have a lot more pics in the next month.
Joe
#24
Posted 01 October 2008 - 08:01 AM
Cool, I Just wouldnt be able to own a Mk1 Mini with no external door hingesLooks really good mate!
#25
Posted 01 October 2008 - 11:34 AM
Nick
#26
Posted 02 October 2008 - 06:19 PM
How do those recaros fit? how much space will there be between the seats?
Keep the pictures coming!
#27
Posted 02 October 2008 - 10:09 PM
just out of interest, what dash was in it!? it looked really different through the hole in the bulkhead!
Ed
#28
Posted 02 October 2008 - 10:26 PM
Edited by panelbeaterpeter, 02 October 2008 - 10:26 PM.
#29
Posted 02 October 2008 - 10:45 PM
this is cool! love all your shiny bits!! lol
Ed
Thanks. The car came with the upper dash trimmed away and missing. The lower dash was cut out and laying in a pile of other parts. As for the firewall, I'm imagining a previous owner cut that out to allow some big carbs to fit. Who really knows though. The history of this car is quite a mystery.
My plan is to re-install both the upper and lower dash and install the 3-instrument binnacle, then fabricate a fiberglass housing behind the steering wheel to hold the R1's original dash unit. I'm kind of looking forward to working in fiberglass again. I tried it for the first time a few years back and although the job was messy and a made the part too heavy (way too much resin), the finished product turned out quite nice.
http://www.joe250.co...d/gaugepod.html
Edited by Joe250, 22 October 2008 - 09:37 PM.
#30
Posted 02 October 2008 - 10:51 PM
make sure those exup blanking plugs are knocked in real good - I lost one a fortnight ago and it sounded real bad.
