Olive
#751
Posted 17 December 2007 - 05:49 PM
Surely the access is really poor, even with you hatch and boot open? or do you find it ok working on the car
#752
Posted 17 December 2007 - 08:42 PM
will only get worse once the boot is lined
Ed
#753
Posted 10 January 2008 - 11:02 PM
#754
Posted 13 January 2008 - 03:15 PM
Just curious, as i haven't put mine on yet, wondered how well it worked!
#755
Posted 13 January 2008 - 03:24 PM
The problem is gaining access to the bolts currently there.
Also the time i have had access to the garage ive had something else to sort
Will happen eventually, but work is slowing progress.
#756
Posted 11 February 2008 - 11:29 PM
Main problem was getting hold of a dam alternator
Nothing much planned for the near future, havent been able to get back to lincoln to do anything because of the alternator, but Ill be picking up my other car when its had its paper work sorted, (sometime next month now), and still on the lookout for a workshop/garage, but doubt ill find something nearby. Although a guy from work said he thinks they wouldnt mind me using the garage at work over the weekends as long as i clean up and out by monday. :wink:
Should soon be able to get some tools that ive been saving for. Just still have other things to pay off as well
Ed
#757
Posted 11 February 2008 - 11:44 PM
#758
Posted 12 February 2008 - 07:09 AM
G13B is more the block, but yes its normally called G13B engine
GTI DOHC is the one you want 1298cc (SOHC is 1324cc)
#759
#760
Posted 12 February 2008 - 09:03 PM
#761
Posted 12 February 2008 - 09:05 PM
#762
Posted 18 June 2008 - 08:56 PM
I haven't done anything to the mini since it was put in my mums garage.
However i have been thinking alot as to what to do with it, mainly because it might not be very long until i have a garage
I have several engine ideas, as well as several body ideas.
At this point im looking for suggestions and what people think.
I would like to be able to do some track days and possible see about the 16vMiniClub sprint championship! But also like the idea of a summer car for shows and trips out. I have an daily driver and will probably invest in a trailer for the mini so no need to worry about braking anything.
So my ideas / options are as follows:-
Body:-
1. Standard
2. Body chop (similar to Minus)
3. Speedster (body chop and no roof / windows)
Engine:-
1. as is (RWD with 5 speed box)
2. Swift on mini gearbox in the front (my other project)
3. Swift on mini gearbox in the rear
So absolute minimum would be as it is but with a strip and rebuild, and id probably alter the rear suspension a bit.
Ed.
#763
Posted 18 June 2008 - 08:59 PM
would think about the chop but thats a hefty job!
#764
Posted 18 June 2008 - 09:01 PM
#765
Posted 18 June 2008 - 09:03 PM
