Olive
#616
Posted 21 March 2007 - 05:42 PM
Cheers buddy
#617
Posted 11 April 2007 - 05:19 PM
#618
Posted 11 April 2007 - 05:28 PM
At least you've started again!
#619
Posted 22 May 2007 - 12:22 PM
The things ive been doing recently are:-
Cleaned and sprayed the bulkhead and Re-run the fuel pipes under the car
(This pic is courtesy of Bec!!)
Yes i know the subframe still needs sorting, It will get powder coated along with other bits in the future, for now its doing its job.
Added some bars for the harnesses (other harness still to fit) and this is also where the bulkhead will attach to.
Order some metal to make a bulkhead (and the next special project!!)
I was cut to approximate length by the supplier so i should just need to shape the edges.
and 1000 rivets to attach it!!!
and i even put in the front carpet for the fayer. (and its already dusty!!!!)
Ive bought some suspension bits but will post a pic when they turn up!! (hopefully tomorrow!!!!) Its nothing drastically special but it should help handling.
Just waiting on a second floor member to be able to mount my seats when ive done my bulkhead!!!
#620
Posted 22 May 2007 - 12:48 PM
Yyyeeeeaaaayyyyy! Olive is the work of a genius! I'm still in love with the dashboard and have you decided where abouts you're going to put her name in rivets?
Keep up the top work Ed
#621
Posted 22 May 2007 - 03:19 PM
Is that the dashboard or the dials? The dashboard is only temporary until i buy another one (after i get a job
I may rivet it in the door
#622
Posted 22 May 2007 - 03:28 PM
#623
Posted 22 May 2007 - 03:37 PM
#624
Posted 22 May 2007 - 04:50 PM
#625
Posted 22 May 2007 - 06:00 PM
#626
Posted 22 May 2007 - 06:36 PM
#627
Posted 22 May 2007 - 07:03 PM
Yum!
#628
Posted 22 May 2007 - 07:11 PM
#629
Posted 22 May 2007 - 09:04 PM
Ive still got to sort out some of the bits, but the speedo and rpm work, as well as most of the lights.
I just have to sort the Temp and fuel gauge (need a fuel sender to start with).
I did talk to Mark about it, but he said it would cost alot and wouldnt be worth it and that i should just get some other dials
So i did it anyway. Got a speedo corrector and it works fine, seems pretty accurate.
#630
Posted 23 May 2007 - 10:49 AM
'I can be bothered to give you a helpful answer'
It really grinds my gears!!
