Olive
782 replies to this topic
#526 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 21 December 2006 - 11:56 PM
Also on the way back i found out (heard) the water pump is on its way out. :w00t:
#527 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 22 December 2006 - 01:28 AM
good to see you have the drive shaft fixed so quickly shame about the waterpump now giving out
#528 ed4ran
ed4ran
  • 2,849 posts
Posted 22 December 2006 - 01:31 AM
Gonna check the belt and the tension to see if that might be causing it just incase, otherwise ill have to order new one :w00t:
#529 mini93
mini93
  • 8,615 posts
Posted 22 December 2006 - 01:36 AM
find out the cause for the snappage then? might be good for a new one...peace of mind and all that
Edited by mini93, 22 December 2006 - 01:36 AM.
#530 ed4ran
ed4ran
  • 2,849 posts
Posted 22 December 2006 - 01:38 AM
Probably just too much go pedal and not the most idle method of joining it together.
Will be replacing them in the future, but for now that have to last till i can get a job.
#531 mini93
mini93
  • 8,615 posts
Posted 22 December 2006 - 01:44 AM
aah will you be going sutom jobbies when you get the chance? how did you insure they were welded parralel in the 1st place, because we had a shortened propshaft in a locost at college and if it wasnt parralel then it would act like a skipping rope motion sending it out of balance...causing streas crack eventualy leading the failure
#532 ed4ran
ed4ran
  • 2,849 posts
Posted 22 December 2006 - 01:48 AM
I clamped it in a large piece of Angle iron. :w00t:
#533 mini93
mini93
  • 8,615 posts
Posted 22 December 2006 - 01:51 AM
woo the amount of engineering, but hey if it works it works right!
#534 ed4ran
ed4ran
  • 2,849 posts
Posted 22 December 2006 - 01:53 AM
:w00t: yeah
#535 Bec
Bec
  • 5,900 posts
Posted 24 December 2006 - 04:44 PM
Hey Ed, that lift Olive is on in the second pic has something to say!
#536 ed4ran
ed4ran
  • 2,849 posts
Posted 24 December 2006 - 05:13 PM
:X Dirty girl!!
#537 Jammy
Jammy
  • 25,397 posts
Posted 25 December 2006 - 11:34 PM
How did you get around the problem of the alignment equipment not fitting onto the tyre?
#538 v8mini
v8mini
  • 726 posts
  • Local Club: Minis on the run
Posted 26 December 2006 - 12:00 AM
looks like he's got some cardboard on the top of the tyre to lift it up in the pic
#539 ed4ran
ed4ran
  • 2,849 posts
Posted 26 December 2006 - 05:15 PM
Yeah had the problem of it not fitting,
had to take the extensions off the bottom and it still hit the floor and raised it all off :X so we just used cardboard to lift it enough.
#540 ed4ran
ed4ran
  • 2,849 posts
Posted 04 January 2007 - 02:34 PM
Should be going for an RR on Sat 13th :D
