Olive
782 replies to this topic
#391 minivanman
minivanman
  • 3,454 posts
Posted 17 September 2006 - 07:27 PM
Sounds good Ed! cant wait to see it finished. Will you be taking it to drag wars next year?
#392 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
i should think so!! :-
#393 Bec
Bec
  • 5,900 posts
Posted 17 September 2006 - 08:16 PM
Oh will ya get some fluids in Olive soon then and go for a spin round Scampton way? :- Pretty please??
Vern says he already fancies Olive (he's such a tart).
#394 ed4ran
ed4ran
  • 2,849 posts
Posted 17 September 2006 - 08:40 PM
lol, We'll have to see!! :D :-
Ive got to wait for these last bits and they won't be here on monday so its likely to be later in the week that i get to drive her. :errr:
#395 Bounce
Bounce
  • 2,197 posts
Posted 22 September 2006 - 05:55 PM
Well??? Any news yet ed???
#396 ed4ran
ed4ran
  • 2,849 posts
Posted 22 September 2006 - 08:42 PM
Required parts still havent shown, but i know they are in the post now, so im hoping tomorrow, but ive got some other bits to sort before hand so ill get onto them first thing.
#397 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 01 October 2006 - 09:47 PM
is this on the road now ED4RAN?
#398 ed4ran
ed4ran
  • 2,849 posts
Posted 02 October 2006 - 09:13 AM
:gimme: nope, still waiting for parts which "should" have been posted friday,
so i gave them saturday as well, so "if" they were posted then they "might" be here sometime this week. :gimme:
But i had a problem i had to sort out though, because of the way the injection stuff works and the way i was operating the fuel pump (just on its own switch)
i ended up with ALL the cylinders full of fuel!!! :w00t:
and this wouldnt have been bad by itself, but i could hear a dripping which was the fuel from the cylinders dripping into the oil!! :gimme:
and you dont have to know engines to know that is bad. (4.5Ltrs of Oil wasted).
So i drained the oil/fuel mix and dropped the sump as far as i could (frame is in the way) put some more sealer on the sump,
and sealed a little hole on the sump that was hidden by the frame,
and put it all back together again, and now installed a wire so the ECU controls the FP.
On top of that i had a exhaust leak so that came apart for some sealer as well.
Sooo hopefully today i can do some tuning and get the engine running better so that when the parts do show i can try driving it. :dontgetit:
Edited by ed4ran, 02 October 2006 - 09:14 AM.
#399 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 02 October 2006 - 03:51 PM
cool, keep us updated fella.
#400 ed4ran
ed4ran
  • 2,849 posts
Posted 08 October 2006 - 05:56 PM
Well after a problem with one or possibly 2 cylinders not firing (believed to be one half of the coil pack being iffy, gonna get another to check)
i did a compression check and #2 seemed funny so i decided to remove the head for a look, and with the head off i also decided to strip it and reseat the valves.
Got to clean all the valves and put new valve stem seals in and finish cleaning the head
then stick it back together all in time for the new coil pack.
Also i might stick the standard ecu and stuff on just to get it running for now, and play with megasquirt later.
:D
#401 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 08 October 2006 - 06:10 PM
Cool, keep us updated mate.
#402 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 09 October 2006 - 07:59 AM
ha ha thats a cool GIF. What did you use for cleaning off the carbon?
#403 ed4ran
ed4ran
  • 2,849 posts
Posted 09 October 2006 - 09:06 AM
Little wire wheel on a multitool,
Got to get some more today, and ill probably do all the ports as well.
Then im going to blast a load of air through it to make sure its all out,
and then clean up all the valves and reassemble.
I might take this oppotunity to strip and paint the cam cover as well.
#404 ed4ran
ed4ran
  • 2,849 posts
Posted 10 October 2006 - 09:33 PM
Well the head is back on, :proud:
along with the timing belt, alternator, and inlet manifold,
I even got around to cleaning the cam cover up so its quite shiney at the mo,
(got some paint for it as well, but a few bits need finishing)
Hopefully tomorrow a replacement coil pack should turn up and i can see if that was the problem with the unfiring cylinder.
Before that happens ive got to put the exhaust back on, which i painted, and filled in some little holes that were in the welds
(black soot showed me where they were!!!!)
Ive also got to add some water to the coolant to top up what came out of the head.
#405 Bounce
Bounce
  • 2,197 posts
Posted 11 October 2006 - 08:18 AM
Mate, i bet your itching with anticipation! I know i would be!!
Come on Mr Postman!!!!
