My Mk1 Turbo
#46
Posted 20 December 2009 - 12:16 AM
#47
Posted 20 December 2009 - 12:32 AM
1380cc stage 4 minispeed eng has not done mile
webber 45
KAD alloy rear swing arms
KAD Heavy Duty Adjustable Rear Camber Brackets
KAD front anti roll bar, two piece
KAD rear blade type anti roll bar
KAD adjustable front tie rods
KAD alloy handbrake quadrants
KAD Gear linkage kit
KAD Adjustable bias pedal box
KAD back disc kit
SC adjustable engine steadys
brake and fuel plumbing is from earl's performance plumbing
MINISPORT 4pots on coopper discs
6 point cage with sum more bars added
home made dash
gaz front shocks
protech alloy shocks on the back
twin tanks
mini life wheels
MK1 SHELL which has had genuine panels fited
rear valance
front wings
a panels inner and outer
front panel
1/2bootfloor and battery box
complete mk4 floor
rear panels lowerhalf
rear dry subframe
wet front subframe which is now dry on wet arms
AND LOTS MORE BITS I CANT THINK OF AT THE MIN
and set up like this
f&r geometry set the corner weights
corner weights are as
N/S/F:200KG O/S/F:206KG
N/S/R:119KG O/SR:123KG
total weight with no driver and 1/4tank fuel is =647kg
.The geometryis set out as
tracking-F toe out1.5 R toein 1mm
camber-F 0.5deg neg R0.75 deg neg
castor -4 deg both sides
hope this helps
Edited by mad mk1, 20 December 2009 - 12:36 AM.
#48
Posted 20 December 2009 - 12:59 AM
#49
Posted 26 February 2010 - 08:48 PM
I will let the pictures do the chatting.
The old dash
The new dash
The battery in
water pump blanking plate
The rad all in and working well
#50
Posted 26 February 2010 - 08:53 PM
#51
Posted 26 February 2010 - 08:55 PM
Edited by mad mk1, 26 February 2010 - 08:56 PM.
#52
Posted 26 February 2010 - 08:58 PM
#53
Posted 26 February 2010 - 09:01 PM
ooo yes everyone the car was in the mini mag this month
Edited by mad mk1, 26 February 2010 - 09:04 PM.
#54
Posted 26 February 2010 - 09:26 PM
How do you notice the lack of fan noise with that dirty great Weber just the other side of the bulkhead?!!!
JR
#55
Posted 26 February 2010 - 09:30 PM
#56
Posted 26 February 2010 - 10:02 PM
#57
Posted 27 February 2010 - 08:42 AM
#58
Posted 27 February 2010 - 01:13 PM
#59
Posted 27 February 2010 - 01:31 PM
I am in the middle of redoing mine. It has a 1293 currently but am considering a minispeed concept 37 1380. Just wondering how did you find them for your engine and how is it going for you. Have you done many miles?
#60
Posted 27 February 2010 - 01:35 PM
How are the works style dashboards attached to the rails? & where did the piping come for for the rear seat lip, also I noticed it on the rear valence and the lip under the front bumper.
