I did everything else by the book, apart from:
To knock the joint off the shaft, push the shaft back into the inner CV then, using a g-clamp or other suitable clamp, clamp the drive shaft to the bottom arm. There is a groove on the shaft which will assist. Then bash off as per the book.
Refitting: Again go by the book - apart from compressing the circlip with two screwdrivers. One screwdriver will suffice, if you are careful and patient. Push the new joint up against the circlip, then poke it into its groove using one small flat screwdriver. As you poke the circlip, maintain the force against it. You will need to poke it in several places, but eventually the joint will go over it. Then just tap the joint home with a soft mallet.
Info may be of use to some
