Wet & Dry
Posted 12 July 2008 - 12:56 AM
Would there be any reason for this? What are peoples recomendations? Stay with it wet or should i go back to using it dry and investing in a new face mask.
Also while i am here can anyone recomend a good filler to apply a thin skim coat. I am using Isopon P38 filler at present but find it dose not apply very well when trying to get a thin coat.
Thanks in advance.
Posted 12 July 2008 - 06:53 AM
Posted 12 July 2008 - 04:35 PM
Dont wet sand filler as it is porous and will only cause problems later. And its not necesary.
Wet sanding is only really for preping primer for basecoats although I know alot of people are just dry sanding because of problems like micro blistering later down the line.
Posted 15 July 2008 - 04:24 AM
Like i mentioned i wet sanded the primer in a few places before. Will this cause problems? I didn’t spray the primer until around the next day so hopefully any water should have evaporated by them. Is this anything to worry about?
Posted 15 July 2008 - 08:41 AM
Posted 15 July 2008 - 08:49 AM
sanding, depending on how much your putting in, start at 80 to knock the big lumps off and work down to 320 as above, but do not use water!
the only time i have seen primer rubbed dry is if people have had to apply a lot of primer to hide inperfections in filler, and only then it was 320 before going to 400 wet and dry, then finally 800 prior to painting in colour.
this is all my opinion and personal experience befoe i upset the pros on here
but give me a shout if you want me to come down dan - still need to grab those wheel nuts off you!
Posted 16 July 2008 - 04:10 AM
Wilson I'm not working Friday night so will be around working on the mini all Saturday if you wana pop round a collect the wheel nuts.
Just give me a call.
Posted 16 July 2008 - 04:39 PM
Posted 16 July 2008 - 11:29 PM
I have also sent you a pm.
Posted 16 July 2008 - 11:54 PM
Posted 18 July 2008 - 04:40 AM
Posted 19 July 2008 - 05:12 PM
colour coat and top coat can be wet sanded
Posted 21 July 2008 - 10:52 PM
Posted 21 July 2008 - 11:12 PM
If your dry sanding and you can lay your hands on an old hoover with the old style paper bag filter .
Then running close to where you are sanding 2-3 feet, will catch alot of the airborn dust out of the atmosphere saving the eventual snow drifts across the workshop.
The constant noise can be a pain though.
however this is no replacement for a good mask.
