Splitting An Engine & Gearbox
13 replies to this topic
#1 minijazz
minijazz
  • 173 posts
Posted 07 July 2008 - 06:52 PM
Hi All
I'm going to replace the engine part of the old girl, leaving my current crisp action gearbox.
Although I'm going to use the haynes manual, does anybody have any useful tips to do this- ?are there any bits in the haynes which don't really work?
any suggestions gratefully received.
cheers colin
#2 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 07 July 2008 - 06:58 PM
Just be patient when removing the flywheel housing and gearbox from the engine. If they are a bit stuck there is a temptation to hit it with a big hammer or jam a screwdriver or chisel in the joint - it's all too easy to damage the alloy housings.
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 07 July 2008 - 07:04 PM
Many ice cream tubs are handy.
Also means you can eat a load.
#4 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
when you have the flywheel off and are ready to split the box from the block , just roll it onto the diff side of the engine and the weight should crack the seal and then you just have to lift it off.
#5 minicooper1.3i
minicooper1.3i
  • 871 posts
  • Local Club: na
Posted 07 July 2008 - 08:58 PM
If the box is stuck to the engine, ensure all the bolts and nuts are out then hoist it a fraction of the ground (1/2"), make sure there's something soft underneath, then tap all around the joind with a rubber mallet or use a block of wood and a hammer. Once it starts splitting, hoist it a tad higher and repeat. You can also use a wooden wedge to help split it. Don't be tempted to use a big screwdriver to prise it apart.
Good luck!
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 07 July 2008 - 09:45 PM
soft rubber mallet. few taps around the transfer casing, clutch wok, gearbox to block join and it will all come apart no bother.
Never had a stuck one yet, gentle tap here and there and just pull it off.
Jordie
#7 mk1leg
mk1leg
  • 9,343 posts
Posted 07 July 2008 - 09:50 PM
use a small jimmy bar and insert it between box and block where transfer gears would be and prise apart................ :)
#8 robba_duck
robba_duck
  • 326 posts
  • Local Club: looking for a new one
Posted 07 July 2008 - 09:53 PM
Have fun getting flywheel off! (but when it is off its a good chance to check ya clutch!)
oh the joys ohh and like every one else has said DONT RUSH and DONT JIMMY (too much :) )
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 July 2008 - 06:23 AM
get an engine stand and then you can turn it upside down a lift the box off....
but easiest way, leave connected to hoist after you've remove from engine, when all the bolts are un-done just life the block up and tap the box....
#10 minicooper1.3i
minicooper1.3i
  • 871 posts
  • Local Club: na
Posted 08 July 2008 - 06:46 AM
Oh yeah, and if you're taking the flywheel off when it's out of the car.....mind your toes! :)
As said above, I'd also recommend changing the clutch and all relevant components (thrust bearing, plunger, arm, and flexible hose to the slave cylinder (use a braided one), etc) unless they're all relatively new. It may be a bit more expense right now, but in my opinion it's worth it for the luxury of changing it out of the car.
#11 haz
haz
  • 568 posts
Posted 08 July 2008 - 04:50 PM
make sure you undo the crank pulley bolt when you've locked your flywheel! its not easy locking an engine without damaging anything when your flywheel is off!
#12 robba_duck
robba_duck
  • 326 posts
Posted 08 July 2008 - 06:00 PM
Hmm well if you got a air tools gun it aint a problem :dontgetit: normally ;-p
but there is a nice split in the end of the crand on the fly wheel end so if you have trouble locking it off get the fly wheel off and use a nice bit flat implement to jam it :withstupid::)
nice and professional hehehe
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 July 2008 - 06:56 PM
But you don't need to undo the crank pully bolt to remove the box from the block...
#14 robba_duck
robba_duck
  • 326 posts
Posted 08 July 2008 - 07:01 PM
no but he may want to take advantage of doing the timing chain and oil seal with the luxury of the engine being out ?
or evan changing the cam hehe...
