Steel standard length roundnose all the way!
The engine also came with ECU, Engine wiring, injection unit & driveshafts!!
Not sure when we'll be doing with the injection manifold yet - The whole thing seems to be quite a massive lump & I would rather not cut into the bulkhead... Whether we can modify the manifold itself or use a different setup, we will have to see!
First thing's first is getting it home!!
But, I would like to keep it on 10's, it all depends on the gearing & FD - I'm not adverse to putting it on 12's or 13's, but I will have to work out which is going to put less strain on the gears & change the FD and wheel size to suit.
I'll also have to have different dials, as my rebuilt Smiths gauges won't work
I've read about handling issues with certain subframe set-ups, too - So will have to take a look at that. Hopefully, with the spring suspension & the fact that the van has a longer wheel base, I won't get too many issues.
I'm also pestering Kris to teach me how to weld, too - I really want to do a load of the work myself!!
