**stolen - Frankie! - Stolen**
#406
Posted 14 May 2009 - 09:17 PM
#407
Posted 14 May 2009 - 09:36 PM
As for an update? ...
I don't want to jynx anything, but engine in tomorrow?
It's had a new clutch, shells, gaskets all 'round, crank, nuts and bolts. The engine now just needs putting back on the gearbox and dropping in to the subframe!!
#408
Posted 14 May 2009 - 10:40 PM
Can't wait to see Frankie with subframes!!
Just want to say a massive Thank You to 'England_Expects' .... true legend!
#409
Posted 15 May 2009 - 08:40 PM
#410
Posted 15 May 2009 - 09:00 PM
The engine's all back together though, but we've decided to hold back for a bit and change the diff! The engine's all built and sitting in the shed - Shouldn't be too much to get it into the subby and on the car now?
We went to put the rear subframe on instead. On cleaning out the threads on the mounting holes, we found that someone's sheered a bolt inside and the remainder of the thread is stuck!
So we've got to try to get that out before the subby goes on
The steering rack's on now though, so should be able to start working on the positioning of the column/interior etc.
#411
Posted 15 May 2009 - 10:08 PM
How far in is the bolt?
#412
Posted 15 May 2009 - 10:09 PM
#413
Posted 15 May 2009 - 10:10 PM
#414
Posted 15 May 2009 - 10:11 PM
#415
Posted 15 May 2009 - 10:13 PM
They will do the job, however if its rusted in i dont want you to break the nut on the inside as that will be bad news. Could try keep drilling it. Dont know what to suggest as touch wood ive never had that problem.
#416
Posted 15 May 2009 - 10:15 PM
(Linky no worky?)
#417
Posted 15 May 2009 - 10:17 PM
Google "bolt remover" second link down.
Edit.
If its rusted you will need alot of penatrating oil and alot of force to free it, can also use heat but id be worried as its already painted
Edited by Jackman, 15 May 2009 - 10:18 PM.
#418
Posted 15 May 2009 - 10:21 PM
#419
Posted 15 May 2009 - 10:22 PM
#420
Plus if the nut comes loose on the inside you need to cut some of the sill out to get at the nut.
Yep! We thought about heat, but it is all stonechipped and waxoyled underneath!
