I have a decent earth as the illumination lamp on the gauge works when i turn my headlamps on, I have run a wire straight from the temperature sender (which was included) to the gauge.
I have isolated the fuse for switched ignition live, which is also wired to the gauge. I did this by taking fuses out, one by one, untill my radio didnt work when i turned the key to ignition. I just cant see why it doesnt work?
Has anybody else had troubles with this, or am i being stupid? I have wired more complex things into the mini before but this has baffled me! I have followed the instructions step by step, but the gauge doesnt move! Might be tempted to swap the cables from the temp sender and ignition live on the gauge and see if that works?
Any suggestions is a great help, im all ears!
Many Thanks ERic
