no other word for it, accept for awsome!
Not even 'awesome'?
The engine looks ace, I'd love to do the k conversion one day.
Posted 05 October 2008 - 07:50 PM
Posted 25 October 2008 - 03:01 PM
Posted 09 November 2008 - 08:08 PM
Posted 11 November 2008 - 10:39 AM
Posted 11 November 2008 - 11:43 AM
Posted 11 November 2008 - 07:05 PM
Posted 12 November 2008 - 09:05 AM
Posted 12 November 2008 - 02:54 PM
Posted 13 November 2008 - 10:34 PM
Posted 19 November 2008 - 08:07 PM
Posted 20 November 2008 - 01:20 PM
Posted 21 November 2008 - 12:30 AM
Posted 22 November 2008 - 09:13 PM
Posted 22 November 2008 - 09:14 PM
Sprocket is just a fussy bar-steward. Lol
Posted 22 November 2008 - 09:27 PM
Sprocket, I've just hooked up to this conversion and that looks awesome. My Mini is running a 1293 A series with standard mods, single 40 Weber etc. it made 90bhp but does still not set the heather alight. This swap looks tremendous. On what I've read around 125bhp looks acheivable from a 1275 which should rev and pull much better than the 5 port engine.
Can I ask you if you are using the SC build manual? I've been on their site but £2700+ is a bit out of my budget. Do you think this could be done a lot cheaper by 'DIY' methods. I don't mean do the maching myself but is there sufficient detail in the manual instructions with cam pulley Pt No's etc?
I think the SC cam pulley kit looks very good but is very expensive, as is the components like the metallic head gasket.
Does the block definitely require to be offset bored (outer 2 cylinders?) and what does this mean to the crank?
I would assume the 16v head is the one to go for, is this the K100RS bike? Will the head require new valves, seals etc as I beleive these things can happily do a bit of mileage?
Lastly, injection or carbs? I assume injection needs a custom ECU (again not cheap) or can the carbs be set up and run quite easily?
Hope you can help and good luck, you're doing a brilliant job. I think it's a great conversion with no significant front end body mods.
