Where Do I Put The Water?
Posted 24 June 2008 - 02:49 PM
Posted 24 June 2008 - 03:03 PM
Posted 24 June 2008 - 03:06 PM
Posted 24 June 2008 - 03:11 PM
Posted 24 June 2008 - 03:15 PM
Posted 24 June 2008 - 03:21 PM
Posted 24 June 2008 - 03:30 PM
Squeeze the hose to make sure its cool 'n unpressurised
Not asking & filling the engine with water through the oil filler cap would be really blonde - it was a brunette that actually did it by the way.
Posted 24 June 2008 - 03:39 PM
They said 710, she said yes it says on the filler cap.
Posted 24 June 2008 - 03:41 PM
Posted 24 June 2008 - 03:49 PM
Posted 24 June 2008 - 03:59 PM
I think it would be worth you picking up a Haynes manual. It'll show you what everything is in the engine bay, you'll need to know where to check the brake fluid and oil levels regularly. You should be able to find a really cheap one on ebay
~ Lacuna
Posted 24 June 2008 - 04:01 PM
Posted 24 June 2008 - 04:05 PM
We will look after you
Posted 24 June 2008 - 05:35 PM
There must be just as many stories about stupid things guys have done in cars though.
Posted 24 June 2008 - 06:04 PM
hehe, thanks guys, you will be glad to hear I wasnt going to put it in the oil bit hehe. I got confused with the bit on the left, is that the washer jet or is that the same thing-ok Im being even stooopider now,hehe, Im really not this dumb normally, well, I have my moments....
See if this helps
No 1 Windscreen Washer fluid.
No 2 Brake Fluid..there's a mark on the side of the clear plastic bit says MAX, it should be upto that..Use DOT 4 or 5 brake fluid
No 3 Engine Oil top up here. Most people use 20/50 oil Duckhams is good
No 4 Radiator , top up with water but also make sure you have antifreeze in there.When you open the cap you will see a metal wire bit in the water, you fill up till water is just covering it
No 5 Oil Dipstick, use this to check level of oil , two lines near the bottom, oil needs to be showing inbetween the two lines, if its to low, then pour more oil into hole No 3
Edited by lrostoke, 24 June 2008 - 06:05 PM.
