Thanks for searching and finding this old thread. However, I suggest starting a new thread as you are dealing with several different issues and not everyone is going to read through the old posts to get to your recently added questions.
Since you bought a later loom for a car with an alternator, the best general advice I can offer is to sit down with a wiring diagram for a later car and trace out the wires you are unsure of. When I bought my car's replacement loom I stretched it out on the floor and used my meter to check it point-to-point and I placed tape labels on the end of each wire so I would be assured of getting things connected to the right points.
In answer to your direct question about the white and white/black wires, yes they are for the coil. The white wire is power from the ignition switch to coil (+). Look carefully at the white black wires. You may find (3) wire ends, not just (2). If you only find two white/black ends, check them with a meter. They are probably terminals on the opposite ends of one wire. If so, one end goes to coil (-) and the other end goes to the distributor. It is the wire that connects the coil to the points.
If you find an additional white/black wire, it will be for connection of a later type voltage pulse sensing tachometer. The end in the engine bay will also connect to coil (-).
